Go to Post As usual this was the programmers fault. - Swampdude [more]
View Poll Results: Swerve or Mecanum? Which does your team prefer?
Mecanum 26 24.53%
Swerve 49 46.23%
Neither, they are too complex and 4wd or 6wd will do the job 31 29.25%
Voters: 106. You may not vote on this poll
Unread 12-04-2010, 17:49
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Mecanum or Swerve?
During the offseason this year, my team has discussed developing swerve drive, but after seeing a number of teams use mecanum with great sucess, I am torn between the two. Mecanum seems simpler and lighter, while swerve seems to give better control and more pushing power/resistance to being pushed. What are the experiences of the rest of the FRC world?
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 12-04-2010, 18:06
sidkulk's Avatar
sidkulk sidkulk is offline
AKA: Sid K
FRC #1403 (Cougar Robotics)
sidkulk will become famous soon enoughsidkulk will become famous soon enough
Re: Mecanum or Swerve?
I think the choice between mecanum and swerve lies in where your robot is best suited to play (offense/midfield/defense).
Offense: Swerve
From watching quite a few matches, swerve seems alot better suited to collect balls and maneuver them into the goal.
Midfielf: Swerve
When your playing the midfield balls constantly keep entering, so you need to be able to quickly "pick up" balls from your zone. And if your in the midfield, theres a higher chance of you needing to go over the bump. So if you use mecanum it seems you need to drive straight to go over on mecanum, but you can go also sideways with swerve over the bump
Defense: Mecanum
Mecanum seems better here because its alot easier to get from goal to goal and just block the goal from other robots scoring.
Team 1403!!!
Unread 12-04-2010, 18:14
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I say go for the 4 or 6 legged robot. First because with 6 legs, 3 legs are ALWAYS touching the ground (Of course unless its falling off a cliff) minimum of 3 legs needs to be on the ground to be stable. Yes I do mean LEGS... Its more adaptable then wheeled vehicles. I mean look at the Protoss Colossus
Unread 12-04-2010, 18:16
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
In My personal opinion, Swerve > Mecanum > Holonomic, and this goes for just about any game.
If you've got the resources, both Manufacturing and Programming, go with a swerve. Swerve drives have the traction advantage over all of the other omni-drives out there. Swerve drives can be complicated to build and drive though, so be careful (Though, you could look into the team 221 swerve modules). Personally, if I ever built and omni-drive for any game I would build a swerve.
Mecanum Drives are probably the most accessible form of omni-drive out there. You can use the kit frame, AM Mecanums, and some off the shelf transmission and have a reliable Mecanum drive. Mecanums lack the traction of a swerve or traditional drive so watch out. Mecanums can climb decently though, so this is an advantage over a Holonomic.
Holonomic Drives are interesting. They're somewhere between a swerve and a mecanum in terms of build difficulty, due to the fact that the wheels must be mounted 90* from one another. (or 120*) They also can be a bit of a handful to drive, and they REALLY don't like un-level playing fields. Holonomic drives also don't push well.
-Dustin Benedict
Unread 12-04-2010, 18:24
AKA: Alex
We had looked into the 221 modules, but had decided that with our small team (12 members) it would be better to have an operable robot with a 6wd than a swerve that did nothing. We also only have 1 programmer and build in a basement, so our manufacturing abilities are very limited.
This was my primary reason for wanting to explore Mecanum...but it seems as though swerve offers better performance if it works right
-Alex
Unread 12-04-2010, 18:34
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
If you want an omnidirectional drivetrain, it appears that swerve would be the best because it gives omnidirectional motion with better traction and without the power loss of mecanum.
However, our meccanum drivetrain has served us very well this year. When we decided we wanted to have omni directional capabilites they were our best option because our team is not capable of building a successful swerve in 2 weeks.
The mecanum does have (atleast) one advantage, swerve has a lag while the pods turn. One other might be weight. If you direct drive 6" mecanums then it should surely be lighter than 4 (or 6) swerve pods, chain, and sterring assemblies. This did not prove to be the case for us this year because we are chain driving 4 8" wheels with 4 toughboxes.
For a game like breakaway where pushing isn't a factor unless your playing a defensive strategy, you really can't go wrong with either.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 12-04-2010, 18:43
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Offense: Swerve
Midfielf: Swerve
Defense: Mecanum
No - at least not by our scouting methods. Mecanum robots are immediately removed from our defensive pic list, as are robots with slick wheels / omni wheels. A decently geared robot with traction wheels will have no problem moving a robot with slick/omni or mechanum out of their way and scoring.
Mechanum are a neat idea (as are omni wheels), but once you bring robot to robot contact into the equation, I'd much rather have robots with traction that won't get pushed out of the way easily.
Regarding any lag time with swerve modules: If you have it programmed correctly, your swerve modules should never have to turn more than 90 degrees from any given point. When you keep in mind that a tank drive has to "turn" before it drives forward, there really is no lag in a well-done swerve drive when compared to a tank drive. When you take into account acceleration time, there really isn't any lag in a swerve compared to a mechanum either.
You may want to note, however, that except for a few teams, most teams do NOT do swerve every year. Even teams that have done swerve, generally don't repeat it much. That's because it takes so much time, machining, programming etc to make it work well.
Swerve is that thing that every team has to try at least once. They try it, they may win a couple engineering awards with it: then most teams rarely do it again.
Unread 12-04-2010, 18:44
Chris is me's Avatar
AKA: Pinecone
Here's my thoughts on the matter. Full disclosure being that I have yet to assemble a swerve drive in anything other than concept sketches, and my mecanum experience is also somewhat limited.
Mecanum drives are overrated, heavily. Often, people decide that they need the ability to strafe, or they decide "maneuverability" is important, so they jump to the conclusion that they should build a mecanum drive. Mecanum drive is a very specific tradeoff. You exchange drive efficiency, resistance to defense, and a bit of speed for strafing. If teams spent more time prototyping bases to determine how well a 6WD does what they aim for, and how much better a mecanum does the same job, I imagine there would be a few less mecanums around. Well driven mecanum robots have seen success in FRC, though, especially this year. 2008 had several, this year there's teams like 190, 230, 188 rocking the mecanum.
Swerve takes away some of the disadvantages of mecanum, while adding extreme complexity in design, build, and driving. Extensive preseason testing should be done with a swerve base before most teams consider the option of building one. From what little experience I have, it's a completely different ball game.
So basically, The question shouldn't be "mecanum or swerve", it should be "what traits of a drivetrain are most important this year?", and you should pick based on what is most important.
Extensive prototyping will always help you make more informed decisions on any part of the robot, including drivetrains. I would encourage any team considering anything new to do it!
A question: Do you remove half and half teams from the list (2 traction 2 omni)? Personally I rate them lower but not completely off.
(I also generally avoid mecanums with any pick, personal preference, but there are exceptions to every rule)
Unread 12-04-2010, 18:46
run the trap!!!
Team Role: Human Player
In my six years of competing in FIRST I don't remember a single mecanum robot ever dominating a competition.
The powerhouse teams have built swerves, tank-drives, and more unusual designs like 71's shuffler and the 148/217 nonadrives. But I can't remember any of the top teams EVER using mecanum.
I can only think of a few cases in which a mecanum robot even won a competition.
Why is this?
Is it simply two difficult to write controllable code?
Are they just too inefficient?
Not enough lateral traction?
Or has the mecanum drive simply never been perfected?
I've seen those mecanum forklifts, I know what the technology is capable of...
-Philip J. Fry
Unread 12-04-2010, 18:49
alicen's Avatar
alicen alicen is offline
Zebra Committee
alicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nice
I have to disagree. This is the third year my team has done mecanum drive, and we were able to play defense well. Defense doesn't necessarily have anything to do with pushing if you're maneuverable enough.
If you want to find an holonomic drive that also has pushing power, you might try over the summer looking into mecanums that have a mechanism which locks all the mech rollers.
Peachtree Regional Volunteer since 2003
Unread 12-04-2010, 18:50
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
What about a 2 wheel drive? It can turn very tight and stuff
Unread 12-04-2010, 18:53
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Another drive system you could research is a kicker drive system, also known as a slide drive system. It's basically a 4WD setup with omni wheels, with a fifth powered omni wheel mounted in the center of the chassis, that allows the robot to strafe.
We've never built one for FRC, but many for VRC. I'd love to prototype one that would be FRC-ready though.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 12-04-2010, 18:55
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
-Nick
But you can strife with regular omni.
AKA: Pinecone
While true, a robot that can push is almost always more defensively useful than a robot that basically can't. I'm a pretty strong advocate of "defense != pushing", but I'd still rather do it with an XWD.
Except you lose significant efficiency in most directions, when a slide drive lets you make the primary direction of travel more efficient than the others. For example, if you have 5 CIMs, you can have a 100% efficient 4 cim forward drivetrain, while only using CIM 5 to go sideways. With a holonomic drive, you are stuck with 4 cims and the inherent efficiency losses that come with them.
Unread 12-04-2010, 18:56
ttldomination's Avatar
Sunny
Mecanum and Holonomic involve great loses of power that drives like Swerve tend to provide for you. But swerve drives require weight and a certain skill level. A lot of teams this year saw that they had the need for the maneuverability, but not necessarily the experience/resources for a swerve, and mecanums offered an easy solution.
1648: 2013-2014
5283: 2015
Swerve Drive DuskProgrammer Programming 7 16-01-2010 09:29
Swerve vs. Mech? yoshibrock Technical Discussion 24 15-01-2010 13:34
Swerve drive 4, 2+2? kirtar Technical Discussion 18 02-04-2008 06:58
Swerve Drivetrain Pelicano234 Technical Discussion 18 13-05-2007 12:55
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
