Go to Post Bumper quality is an "attention to detail" measure. Teams that get little things right tend to do better on the big things. - vhcook [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 04-04-2010, 23:57
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: What is CAN?...
I modified it so that when it throws an exception (in java) instead of actually throwing it, printing the stack trace to the DS LCD box and blinking a light on the dashboard (<- that part didn't quite work, datatype mismatch)
If something can throw an exception make it a compile time catch, because if you forget to handle it somewhere in your code, you will have a bunch of angry drivers telling you to fix your code.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 12-04-2010, 17:26
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Re: What is CAN?...
I am slightly confused now. I thought that CAN used CAT5 connectors, but I am now getting the sense that it is phone line. Can someone provide a definitive answer?
Thanks!!!!
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 12-04-2010, 17:57
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: What is CAN?...
CAN cables are RJ-11, Serial-CAN cables are RJ-12 (RJ-14 works also for regular CAN. The standard phone wiring isn't used though - 2 CAN wires: CAN H and CAN L, make up the regular CAN cable. A Serial version includes the CAN wires, plus 3 serial lines (RX, TX, and GND)
So in a way, yes it is phone wires and connectors, but the wiring is slightly different
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 26-06-2010, 12:18
techplex's Avatar
techplex techplex is offline
Blake B
AKA: Blake
FRC #4909 (The Bionics)
techplex is just really nicetechplex is just really nicetechplex is just really nicetechplex is just really nice
Re: What is CAN?...
So....
I've been searching....
Is there anywhere that says "This is how to setup CAN"?
I understand there are two means:
1.) Serial to can with a Black Jaguar
2.) 2CAN Adapter for CAN to Ethernet from andymark.
It seems as buying a Black Jaguar is the less expensive route. What is needed to connect the serial to the telephone connection. Is there a pinout? Is it something to buy, and if so where?
Is there a spec on the terminator. 135 ohm resistor between which wires? Can I buy them somewhere?
Thanks,
Blake
Electrical, Programming and Design
Creator FRC Q&A 2017
Mass FRC Team 4909: The Bionics
Maine FRC Team 5122: The RobOTies (2014-2015)
Maine FRC Team 2648: Infinite Loop (2008-2011)
Unread 26-06-2010, 13:23
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: What is CAN?...
Take a look at the Getting Started Guide for black jaguars, found on this page:
http://www.luminarymicro.com/jaguar
It's under the name "Getting Started (MDL-BDC24)"
You're interested in the section called "Network-based control".
-- Marshal Horn
Unread 30-06-2010, 23:58
techplex's Avatar
Blake B
AKA: Blake
Re: What is CAN?...
So I wanted to sum up what I learned:
There are two methods for First teams to use CAN (Controller Area Network)
1.) Serial + Black Jaguar Cost: ($85 + cabling accessories)
Pros:
✔ Less Expensive
✔ No Firmware upgrade required
✔ Keeps Ethernet port 2 free for Camera
Cons:
✘Serial Connection for Firmware Updates
2.) Ethernet and 2Can Cost: ($199 + cabling accessories)
Pros:
✔ Ethernet Connection for Firmware Updates
Cons:
✘Cost
http://www.andymark.biz/am-0545.html
Both:
✘Require a Firmware update
So from this, we decided to look into Option 1....
Black Jaguars(MDL-BDC24) can be purchased here: http://sales.digikey.com/dkes/FirstR...ompetition.asp
and Instructions on how to fabricate the needed cables can be found here: (pg 29)
http://www.luminarymicro.com/index.p...8&Itemid=59 1
Best,
Blake
Unread 01-07-2010, 00:02
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Re: What is CAN?...
Yep, that's right.
If you have any trouble, feel free to send me an email.
-- Marshal Horn
IRI - What Can Be Improved Chris Fultz Off-Season Events 47 06-08-2007 08:27
can anyone please tell mw where or with what can i lear programing in C techsage Programming 7 23-08-2005 00:25
What can i do? yangotang Website Design/Showcase 14 12-01-2003 23:55
What can we do to get noticed WorkThoseBuns Regional Competitions 17 21-03-2002 20:57
