Go to Post DO NOT THROW THINGS AT THE PROGRAMMER! - demosthenes2k8 [more]
Unread 12-04-2010, 19:14
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Legged Robots
Were any legged robots actually been made by a team and competed with? I believe that it is a very good form of robot locomotion. There are 1, 2 , 4, 6 legged robots that I know of, even Leg/Wheel Hybrids like the RoboTrac. How come they were never really attempted by any teams? I completely understand the cost of the robots, but 1 competition is like 6k, I can make a decent sized 6 legged robot with that budget, just by not going to 1 regional.
RoboTrac:
The Epicest 4 legged robot in the world:
http://www.youtube.com/watch?v=cHJJQ0zNNOM
People can say that it is unstable... But you only need 3 points of contact to the ground minimum to be stable, the Hexaped robots are highly stable.
http://www.youtube.com/watch?v=-Soq9qpK5Ac
Unread 12-04-2010, 19:20
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Legged Robots
Maybe I'm missing something. Can you list some advantages you see to a legged robot over a robot with wheels for FIRST applications?
I'm not even going to get into the disadvantages I see until I figure out what the benefits are.
Unread 12-04-2010, 19:24
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Legged Robots
Stability (6 Legged Robots)
Adaptability
Maneuverability
Innovation
Unread 12-04-2010, 19:26
spacewolfx's Avatar
spacewolfx spacewolfx is offline
Gear Box
FRC #3176 (Purple Precision)
spacewolfx will become famous soon enoughspacewolfx will become famous soon enough
Re: Legged Robots
Adaptability
Maneuverability
Innovation
how does it be more maneuverable than a regular wheeled robot?
2010 Rookie All-Star
Unread 12-04-2010, 19:29
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Legged Robots
You can literally walk over the bump, Not really affected by height change, You can even jump if you get that far, I applaud you. IDK but Dogs can go anywhere, they have 4 legs.
Unread 12-04-2010, 19:34
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Legged Robots
So you are suggesting that a legged robot that has 3 contact points at a given time is more stable than a wheeled robot with 4 or more contact points?
Maneuverability
I have never seen a video of a legged robot I would consider more maneuverable than a drop-center 6 wheel FRC drivetrain, not to mention something like a mecanum or swerve drive.
Adaptability may be debatable, I don't know enough about legged robots to say whether they are more or less adaptable to different terrains (assuming that is what you mean).
Innovation is definitely an advantage of a legged robot. If that is one of the goals of your team that should definitely factor in. Personally I don't value innovation for innovation's sake in this competition for teams I work with. I always work to have us design the best robot to play the game we can, if that means that some parts are tried and true, boring things then so be it; if it means that we need to go somewhere teams haven't gone before than that's fine too.
I definitely understand and respect teams that try each and every year to come up with something completely innovative. I think that's really cool. It's just not for me.
Unread 12-04-2010, 19:37
BHS_STopping's Avatar
BHS_STopping BHS_STopping is offline
The Freshman
FRC #0842 (Falcon Robotics)
BHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant future
Re: Legged Robots
If we're going to be loose with our definition of "legged," I would consider Beatty's 2002 machine to be a "crawler" of sorts. Check out some of their videos on TBA, it's really an elegant mechanism. However, they weren't champions in 2002 because of the qualities you indicated. In fact, their machine was simply very slow and powerful, but guaranteed a victory if they could snag all 3 goals at the start of a match.
Their mechanism was simply two sets of one-way shoes which slide forward on the carpet. In this sense, the robot could easily be pushed forward, but impossible to stop if you were pushing backward. It would take a minute to get where it needed to go, but the simplicity of the design (469's mechanism reminded me of this this year) was just phenomenal.
[/The Freshman]
Unread 12-04-2010, 19:40
wo-bot 141's Avatar
wo-bot 141 wo-bot 141 is offline
AKA: cory walters
FRC #0141 (WO-BOT/COLD LOGIC)
wo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to behold
Re: Legged Robots
team 71 in 2002 oe 2001 i cant remember. but any ways they would flip down garb the goals and crawl over to the other side of the field. call it the game breaker bot that year if you like. but they used legs to get across if i recall. so legs can be used for power when speed is not needed.
Unread 12-04-2010, 19:41
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: Legged Robots
This big dog thing creeps me out every time I see it walking....
I can't think of a game it would be good for.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 12-04-2010, 19:42
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: Legged Robots
Wasn't it team 71 (correct me if im wrong) who had a walking bot a while back???
Someone beat me to it
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Legged Robots
Its the giant one that has the 2 big arms? Dang, thats pretty epic, but so slow
Unread 12-04-2010, 19:47
Chris27's Avatar
Chris27 Chris27 is offline
AKA: Chris Freeman
FRC #1625 (Winnovation)
Chris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant future
Re: Legged Robots
Adaptability
Maneuverability
Innovation
Definitely no...
(at least from my experiences working with Chiara and Nao robots).
Unread 12-04-2010, 20:03
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
Re: Legged Robots
As a design rule of thumb, legs should only be used where wheels won't work. Legs are more complicated, slower, less powerful, and difficult to program. Wheels are simple, fast, and reliable.
There aren't many places where wheels or tracks won't work.
That said, it would still be cool to see a fast legged robot in a FIRST competition. Not saying it can't be done, it's just not for rookies.
Unread 12-04-2010, 20:07
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Legged Robots
We will see next year in the LA regionals who's team has the Fully Autonomous Possibly legged robot... I am going more toward wheel, but a wheel/leg hybrid sounds cool
Unread 12-04-2010, 20:19
Re: Legged Robots
Actually, if you know ahead of time that you'll be walking on a flat floor (where wheels work well), you can do a fairly simple mechanical linkage (one motor on each side driving three legs) hexapod that will scoot around and look impressive. It might not win a competition, but it might get a design award!
Robots Advantages Jordan2389Diaz General Forum 17 12-02-2010 15:02
Letting robots on top vs getting on top of robots sanddrag Rules/Strategy 44 09-02-2007 10:50
Robots FlyingDutchman Chit-Chat 0 12-01-2007 17:34
Are FIRST robots actually robots? EHaskins General Forum 39 14-12-2006 21:40
two robots utishpenguin Rumor Mill 26 03-10-2002 02:57
