Go to Post I HAVE IT PROGRAMMED!!!! Ive just been forbidden from testing it... they think ill make the bot explode. >.> - Got_POSTWAFFLE? [more]
Unread 04-13-2010, 12:19 AM
CraigHickman
Posts: n/a
Re: IR Scanning Method Of Object Recognition
I work for a company (linked in my sig) that does Stereo Cameras. Stereo cameras allow machines to do exactly what you're hoping to do with this custom laser jig, but all in one nice and tight package. Here's a simple breakdown on how it works:
1. You know the distance between your camera's two lenses.
2. You can "measure" the distance between two features in an image.
3. Since you know the distance between lenses, the the distance in pixels between two features, through calibration you should be able to identify and quantify the distance between features. One "difference" is called a Disparity.
4. Using a nifty, already developed piece of software called SVS (credit to this goes to SRI's vision lab, more specifically Kurt Konolige, my boss), you can lay out an image that plots all Disparities in color to represent the depth and distance. A good example can be found here http://www.videredesign.com/index.php?id=65 if you're curious.
Vision is awesome, and can do just as much (if not more!) than some laser systems.
If you're hooked on lasers, go check out Hokuyo Automation's products. We use some of their laser rangefinders for our SLAM bots. They're a little pricy for FIRST, but man oh man are they cool.
UI Board Object Specs 3DWolf Control System 2 12-10-2008 04:13 PM
rangefinding/object detection sciguy125 Electrical 14 01-13-2008 08:36 PM
FALCON Open-Source Object Recognition System Now Available! Eldarion General Forum 26 05-19-2007 10:58 PM
Object Enablers SherryG Inventor 1 04-07-2006 10:01 AM
pic: New hi-tech fad: scanning LED message name tags CD47-Bot Extra Discussion 11 03-29-2004 11:58 PM
