Go to Post It looks very simple to build, and I like simplicity. - Nick Lawrence [more]
Unread 13-04-2010, 00:42
Bigcheese Bigcheese is offline
C++0x FTW!
AKA: Michael Spencer
FRC #1771
Bigcheese is a jewel in the roughBigcheese is a jewel in the roughBigcheese is a jewel in the roughBigcheese is a jewel in the rough
Re: Unexpected results from Encoder::GetRate()
Here's 4x decoding data with the same changes to Encoder.cpp as listed above.
http://spreadsheets.google.com/ccc?k...E1zX 2c&hl=en
And here's the relevant code for getting the data.
void  updateCSV(void* stream)
	CompetitionRobot1771* r = CompetitionRobot1771::GetInstance();
	std::ofstream& s = *reinterpret_cast<std::ofstream*>(stream);
	static double left_previous_distance = r->m_PMU.m_leftEncoder.GetDistance();
	static double right_previous_distance = r->m_PMU.m_rightEncoder.GetDistance();
	static double previous_time = static_cast<double>(GetFPGATime() - r->m_BumpTestStartTime) * 1e-6;
	double current_time = static_cast<double>(GetFPGATime() - r->m_BumpTestStartTime) * 1e-6;
	double left_distance = r->m_PMU.m_leftEncoder.GetDistance();
	double right_distance = r->m_PMU.m_rightEncoder.GetDistance();
	double left_derived_rate = (left_distance - left_previous_distance) / (current_time - previous_time);
	double right_derived_rate = (right_distance - right_previous_distance) / (current_time - previous_time);
	double left_rate = r->m_PMU.m_leftEncoder.GetRate();
	double right_rate = r->m_PMU.m_rightEncoder.GetRate();
	s << current_time << "," << r->m_CO << ","
	  << left_distance << "," << left_rate << "," << left_derived_rate << ","
	  << right_distance << "," << right_rate << "," << right_derived_rate << std::endl;
	left_previous_distance = left_distance;
	right_previous_distance = right_distance;
	previous_time = current_time;
	r->GetWatchdog().Feed();
void CompetitionRobot1771::Autonomous(void)
	GetWatchdog().SetEnabled(true);
	while(IsAutonomous() && IsEnabled())
		std::ofstream csv("bump_test.csv", std::ios::trunc);
		Notifier csv_update(updateCSV, &csv);
		csv << "Time,CO,Left Distance,Left PV,Left Derived PV,Right Distance,Right PV,Right Derived PV\n";
		m_CO = 0;
		m_BumpTestStartTime = GetFPGATime();
		m_PMU.m_leftEncoder.Reset();
		m_PMU.m_rightEncoder.Reset();
		csv_update.StartPeriodic(0.005);
		foreach(CANJaguar* c, m_LeftJags)
			c->Set(-m_CO);
		foreach(CANJaguar* c, m_RightJags)
			c->Set(m_CO);
		Wait(0.1);
		m_CO = m_BumpTestCO;
			c->Set(-m_CO);
			c->Set(m_CO);
		Wait(m_BumpTestTime);
		m_CO  = 0;
			c->Set(-m_CO);
			c->Set(m_CO);
		csv_update.Stop();
I agree that the problem is with the period returned by the FPGA.
[BB] An unexpected change in plans yodameister General Forum 22 01-12-2009 21:26
Inconsistent reading from encoder get rate rwood359 National Instruments LabVIEW and Data Acquisition 5 13-01-2009 19:10
Results from Drexel, thanks from 365. archiver 2001 1 24-06-2002 02:44
Results from GLR? archiver 2001 0 24-06-2002 02:44
results from regionals archiver 2000 0 23-06-2002 22:31
