Go to Post Paper is not so bad. It is really rare for it to crash or run out of battery, for example... - DonRotolo [more]
Unread 13-04-2010, 08:27
Electrical Engineer
Rookie Year: 1995
Re: Were we ever limited on the amounts of non-CIM motor
Andre,
When you stop to investigate, many gear efficiencies (or inefficiencies) may surprise you. For example:
The Globe motor (KOP a few years ago) had a 77% gearbox efficiency (23% loss). Granted, it was multiple stage (117:1) but it was probably better designed, integrated and implemented than anything you will accomplish in your school's machine shop.
Another example: A Globe gearbox/motor I used in another robotic competition last year (65:1 gear ratio) sported a gearbox efficiency of 66% (34% loss).
Also note that these examples were manufacturer's numbers and likely optimistic...
When we learn physics, we almost always "ignore friction". The real world never does...
Regards,
Mike
Mike Betts
As easy as 355/113...
All the FRC Teams That Ever Were Mark McLeod General Forum 98 28-07-2010 09:50
How close can you mount the IFI Controller to a CIM motor Capt. Quirk Control System 8 20-02-2008 19:37
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
opening up the BaneBot gearbox to install the CIM motor jskene Motors 9 22-01-2007 11:12
dewalt motor VS. CIM motor John Gutmann Motors 12 10-01-2007 18:57
