Go to Post will.i.am should be evangelizing FIRST, not vise-versa. - basicxman [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 25-09-2002, 17:47
C Fox C Fox is offline
#0247 (Da' Bears)
C Fox is an unknown quantity at this point
Send a message via AIM to C Fox
Floor flanges
Thanks for the details. But there's a new probelm. How do i join the PVC to the flanges? They're 2 different sizes. Is there an adapter or something?
Any information would help a great deal.
Thanks again in advance
C.Fox 247 Da' Bears
Unread 25-09-2002, 18:28
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Flange slop - Official
What was done on the game piece was a wood dowel plug was installed inside the plastic and the set screws ( set screws suck ) used to hold in place.
In high stress areas there will be a thru bolt for safety.
Mike Martus
Unread 25-09-2002, 18:49
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
which is official?
is the dowel plug the official answer or has it been deemed official that set screws suck?
Unread 26-09-2002, 15:53
#0247 (Da' Bears)
FIeld Layout
How high are the borders to the OCCRA 2002 field?
C. Fox 247 Da' Bears
Unread 26-09-2002, 15:54
#0247 (Da' Bears)
OCCRA
Has any team built the goal structure yet? If so, how many balls can it hold?
Unread 26-09-2002, 17:48
DanLevin247 DanLevin247 is offline
Missing In Action
#0247 ('da bears)
DanLevin247 is on a distinguished road
Send a message via AIM to DanLevin247
Fox, simple math, if the goal is 6 feet tall, that's 72 inches. Each playground ball is 10 inches. 72 / 10 = roughly 7 balls in the tall portion.
'daaaaaaaaaaaaaa bears!
It's all fun and games till someone gets hurt.....then it's hillarious!
Unread 26-09-2002, 20:43
set screws -suck official
That's now official.
The plug is just for support and will not affect the game piece.
Mike Martus
Unread 27-09-2002, 01:28
Mr. Mac Mr. Mac is offline
#0001 (Juggernauts)
Mr. Mac is on a distinguished road
Floor Flange Options
How authentic do you want to be? We used Kee-Klamp floor flanges (a catalog order item), but the Hazel Park team is using the 1.25" Home Depot floor flanges and screwing a threaded PVC fitting into it, then inserting the PVC columns into them. A quick, low-tech solution would be to take some 2" by 4" boards, form them into a square, drill a 1.25" hole half way through them and stick the PVC into the holes. Whatever's right.
Unread 27-09-2002, 01:45
#0001 (Juggernauts)
Field Border Size
The field border is made from two 2" x 4" boards fastened at right angles to each other; a flat 3.5" side is vertical and faces the playing field. The other 3.5" side lies flat on the carpet and has holes drilled in it every 8' where a 16" piece of 1.25" PVC is inserted vertically; each piece of the PVC pipe has holes drilled into it where ropes pass through; there are two ropes that go through each upright PVC pole and encircle the field. This barrier is not meant to be interacted with by the robots; it has been designed to contain rolling balls and to keep robots from accidently leaving the carpeting. In front of each player station will be a 3' tall, 4' wide barrier made from pipe and Lexan; balls will be able to roll under the barrier as there is a 12" high slot at the bottom where there is no Lexan.
Unread 27-09-2002, 01:48
gail gail is offline
#0469 (Las Guerrillas)
gail is a name known to allgail is a name known to allgail is a name known to allgail is a name known to allgail is a name known to allgail is a name known to all
specs on towers
Can someone please measure the following on the ACTUAL competition tower:
1. The distance from the floor to the top of the plywood (the surface where the PVC poles are mounted)
2. The distance from the outer edge of the plywood to the PVC (not the flanges) ie. the inset distance, both on the encased PVC and the unencased PVC
Thanks.
Unread 27-09-2002, 10:38
Justin Howard Justin Howard is offline
Justin Howard is an unknown quantity at this point
Specs on Tower
The distance from the floor to the top of the plywood is 4 5/8"
The distance from the outer edge of the plywood to the pvc is 2 1/8"
Unread 28-09-2002, 16:49
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
What is the greatest possible diameter of the flanges on the cart? ( The part where the pvc is insearted, not the bottem of the flange.)
Thanks
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 28-09-2002, 19:27
Gadget470's Avatar
A Fire Outside
From DanLevin53:
Consider also the other 5 inches from floor to flanges, 6, MAYBE 7 balls will fit. + 2 in the mini tower
Unread 28-09-2002, 21:04
#0001 (Juggernauts)
Flange diameter
I can't say the exact outer diameter at the top of the cart flange: they are at school and I'm at home now. I'd guess about 1 3/4" but here's a picture: you can guess for yourself...
Unread 28-09-2002, 21:20
#0001 (Juggernauts)
Flange Picture
Something went wrong: I'll try attaching the picture file one more time.
Autocad drawings Jimmy Holmes OCCRA 3 25-09-2003 18:45
New(er) AutoCAD drawings... Brandon Martus OCCRA 1 16-10-2002 14:34
AutoCAD Viewer Gadget470 OCCRA 2 25-09-2002 03:19
Help with Autocad and Bryce 5 Keith Chester Inventor 0 25-03-2002 17:33
AutoCAD, Inventor, or Other D.J. Fluck General Forum 23 31-12-2001 08:59
