Go to Post Coming up next on Pimp My Ride.....Yo man, here is the real deal. A two-oh-oh-six Segway I-one-eighty, with stock rims, stock fenders, and two 3 horse motors that red-line at twelve point five miles per hour. Get ready, because I'm going pimp this ride! - artdutra04 [more]
Unread 04-04-2010, 20:56
RoboGuy RoboGuy is offline
FRC #3452 (GreengineerZ)
RoboGuy is on a distinguished road
Help with CAN bus closed-loop speed control
Will the SetMotorSpeed.vi in LabVIEW set the "speed" or the "voltage" of motors if the Jaguars that are controlling the motors with CAN bus off the digital sidecar? Thanks in advance.
Unread 05-04-2010, 14:07
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Help with CAN bus closed-loop speed control
The "set-speed" should set the speed, with feedback. (it requires an encoder)
I believe it's in RPM, but I don't recall.
The "set-voltage" is proportional; -1 to 1 just like the pwm-based "set-speed" in the WPI libraries.
-- Marshal Horn
Unread 05-04-2010, 15:09
Which sub-pallete are the set-speed and set-voltage vi's in?
Unread 05-04-2010, 15:41
All of the CAN VIs are available on FIRSTForge. http://firstforge.wpi.edu/sf/frs/do/....canjaguar/frs
The VIs included with LabVIEW do not support CAN. The SetSpeed VI that comes with LabVIEW uses PWM and sets a voltage, it doesn't actually set a closed loop speed.
CAN does not run from the digital sidecar, it either runs from the serial port on the cRIO through a black jaguar or from ethernet through a 2CAN. When you said CAN, did you really mean PWM?
Unread 05-04-2010, 23:03
No I meant CAN. I'm sorry I didn't make that clear. I downloaded and looked at those vi's from Firstforge and it seems to me that they want inputs from encoders through the digital sidecar. But is there a way to program the Jaguars in Labview to perform closed-loop speed control by feeding the encoder wires straight to the Jaugars and hooking the Jaugars to CAN bus? (by the way, my team is using gray Jaugars just to let you know)
Unread 10-04-2010, 03:31
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Well, if you're using CAN, then the encoders SHOULD be hooked up directly to the jaguars.
The documentation may not explicitly say it, but if you're using CAN speed control (as opposed to voltage control), the encoders must be connected to the Jaguar, not the digital sidecar.
-- Marshal Horn
Unread 13-04-2010, 15:32
Well, the problem is I don't know how to tell the Jaguars, in LabVIEW, to utilize the closed-loop speed control that the Jaguars already have in them when encoders are wired straight to the Jaguars and the Jaguars are daisy-chained with CAN from the serial port on the CompactRIO.
Unread 13-04-2010, 15:46
Have you looked at the speed control example that is included with the CanJaguar for LabVIEW download from FIRSTForge?
Unread 13-04-2010, 16:17
Yes, but the default form of that example requires inputs from encoders or potentiometers to the cRIO for the code to work right.
Unread 13-04-2010, 18:09
The file I'm looking at "CAN Jaguar - Speed Control Example.vi" does not use encoders or potentiometers on the cRIO. It uses an encoder on the Jaguar.
Unread 13-04-2010, 19:33
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
We didn't use CAN this year so I may off base with this so keep that in mind...
As far as I know, CAN gives you feedback on current. Current is proportional to torque in a DC motor. That means you can perform feedback and control torque, so you won't be directly controlling speed.
Unread 13-04-2010, 19:36
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Current is only one of the control modes.
There's Voltage, Speed, Position, and Current.
Current is often advertised because it is not a readily available option without CAN.
-- Marshal Horn
Unread 13-04-2010, 21:06
Joe,
Would you please post a link to that file you're looking at?
I am told by our programmer (and others) that the WPI CAN/Jaguar VIs they have looked at only support closed-loop speed control performed by cRIO using encoder signals passed to the cRIO, not closed-loop speed control performed by the Jags using encoder signals connected to the Jags.
Thanks.
Unread 13-04-2010, 21:39
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Are you looking at the latest version from firstforge? The C++ version of the code didn't get closed-loop finished until midway through the season. LabVIEW most likely would be a similar situation
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 13-04-2010, 23:04
Thanks, I'll download the latest rev and ask them to look at it again.
Closed Loop Speed Control kgzak NI LabVIEW 16 29-03-2010 21:27
closed-loop torque (current) wheel control for mecanum Ether Programming 3 07-02-2010 00:54
Radio Packet loss + closed loop control system = lunging robot Dave K. Control System 5 20-02-2007 06:09
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
How Can You Make A Closed Loop System???? GRR_340 Pneumatics 6 21-03-2002 12:27
