Go to Post This reminds me of a sports bar where there's a bunch of games on different TV's. Only this is better because it's FIRST. :D - JackG [more]
  #45   Spotlight this post!
Unread 13-04-2010, 23:36
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Re: Unexpected results from Encoder::GetRate()
Originally Posted by jhersh View Post
"UpRisingEdge => count A if B is high"
"UpFallingEdge => count A if B is low"
Here you lost me. I would have been ok if you'd said
"DownRisingEdge => countup A if B is high"
"DownFallingEdge => countdown A if B is low"
Here are the much anticipated logic equations used in the 1x and 2x quadrature decoding mode of the counters.
Count = (ARising | AFalling) & ((BHigh & UpRisingEdge) | (BLow & UpFallingEdge))
CountUp = Count & !(BHigh ^ DownRisingEdge ^ ARising)
CountDown = Count & (BHigh ^ DownRisingEdge ^ ARising)
With this, there will hopefully be no more mystery.
Ok, I'm going to think outloud and see if you agree I see the light.
Lets try an example for 1x: UpRisingEdge = true , DownRisingEdge=false
Assume B is static high so Bhigh=true
Now A channel gets a rising pulse so ARising = true , AFalling= false
Evaluate 1)
Count = true;
(BHigh ^ DownRisingEdge ^ ARising)=(true^false^true) = false;
so
CountUp = true & !(false) = true
CountDown = true&false = false
Hence we count up ....
Now A channel gets a falling pulse so Arising = false, AFalling = true
Evaluate 2)
Count = true:
(BHigh ^ DownRisingEdge ^ ARising)=(true^false^false) = true;
so
CountUp= true &!(true)=false
CountDown = true&true = true
Hence we count down ....
This repeats so with a stuck B channel, it oscillates.
In the case where B is not static , it inhibits the count when AFalling = true because Bhigh= false during that transition.
So I guess I'm with you.
Since this logic requires a transition to count 1x properly, it seems the code should throw a flag when the B is static since this is an invalid input. Otherwise why require it.
[BB] An unexpected change in plans yodameister General Forum 22 01-12-2009 21:26
Inconsistent reading from encoder get rate rwood359 National Instruments LabVIEW and Data Acquisition 5 13-01-2009 19:10
Results from Drexel, thanks from 365. archiver 2001 1 24-06-2002 02:44
Results from GLR? archiver 2001 0 24-06-2002 02:44
results from regionals archiver 2000 0 23-06-2002 22:31
