Go to Post What if, each alliance has a pile of AndyMark equipment in front of them. They then have 2:00 minutes to assemble said equipment, and build a working robot that will race to the other side and grab the other alliance's flag. - Pjohn1959 [more]
Unread 12-04-2010, 22:52
cvitullo's Avatar
cvitullo cvitullo is offline
God of souls
FRC #0830
cvitullo is an unknown quantity at this point
FRC Joystick throttle problems
My team is using the throttle on the Attack 3 joystick for our kicker speed control, but for some reason it's only returning -1, 0, or 1. Never anything else, despite being an analog input. Anyone else have this problem?
We're passing it to a Victor (also, does anyone know the values a victor takes in? I can't find them anywhere) after a bit of math to convert it.
Unread 12-04-2010, 22:57
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: FRC Joystick throttle problems
I believe Victors work the same as jaguars, a value between -1 and 1. Are you looking at the output directly from the joystick? The problem could be in your conversion code
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 12-04-2010, 23:06
cvitullo's Avatar
God of souls
FRC #0830
Do they now. My mentor was under the impression is was 0 - 255. That would explain some of our problems. Can you/anyone confirm that? I don't have any hardware to actually test on right now
By the way, we're switching from LabVIEW to C++ for nationals, so it's kind of... urgent that we figure all this out.
Unread 12-04-2010, 23:09
AKA: Ian Thompson
Both the Victor and Jaguar class implement the same MotorController interface which defines the use of the Set function, so I'd assume they take the same inputs (and I'm 100% sure it's -1 to 1 on jags)
The 0-255 confusion is probably from the IFI system. I've never used it personally, but apparantly that is how the pwms on that board were controlled (no floating point capabilities on IFI)
Unread 13-04-2010, 02:14
Al3+'s Avatar
Al3+ Al3+ is offline
ARTist
AKA: Anthony
FRC #0840 (Aragon Robotics Team)
Al3+ is a jewel in the roughAl3+ is a jewel in the roughAl3+ is a jewel in the rough
Confirmed. The Joystick::GetThrottle() function also returns a float from -1 to +1.
And yes, it used to be 0 to 255 on the IFI control system.
Refer to the help docs that come with WindRiver (I believe it's C:\WindRiver\docs\extensions\something). The return types and such are all in there.
cout << "Hello, robotics. Goodbye, world." << endl;
"The two-axis accelerometer provided in the kit of parts (shown in the picture below) is a two-axis accelerometer." - WPILib User's Guide
Unread 13-04-2010, 02:24
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Sounds like you are storing the joystick axis data in an integer variable. Make sure you store it in a float or a double.
Unread 14-04-2010, 20:46
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
TRY THIS:
if (ThirdStick->GetRawButton(3))
{ Variable->Set( ( ( ThirdStick->GetThrottle() / 2 ) - 0.5 ) ) ; } ;
it works well with our ball magnet
Problem with Joystick Throttle ctcw Java 2 15-12-2009 19:11
Help with programing saitekx36f joystick and throttle sonicx059 Programming 4 21-01-2008 20:30
Joystick problems Golfer241 Technical Discussion 3 14-02-2006 16:35
Joystick Problems anupalsingh Programming 0 23-02-2004 17:50
Joystick problems archiver 2001 3 24-06-2002 02:40
