Go to Post We talked to a team in Las Vegas and next year there will be another team with a 25 drive train. The west coast may never be the same. - nuggetsyl [more]
Unread 14-04-2010, 18:14
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
AUTONOMOUS PROBLEM
I HAVE A PROBLEM, I WROTE THIS CODE FOR AUTONOMOUS:
if ((AutoSwitch3->Get()== 1) && (limitSwitchB->Get()== 1))
CamKicker->Set(1.0);
Wait(1.0);
CamKicker->Set(0.0);
when the third switch on the robot is on it sets the cam kicker. before the camKicker is being is set it is pressing limitswitchb.
but its not working, can anyone help please??
Unread 14-04-2010, 19:14
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: AUTONOMOUS PROBLEM
no, the logic in his if is right. Double-check that the switches are actually sending data. Nothing that I can see with that code seems wrong
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 14-04-2010, 19:15
Al3+'s Avatar
Al3+ Al3+ is offline
ARTist
AKA: Anthony
FRC #0840 (Aragon Robotics Team)
Al3+ is a jewel in the roughAl3+ is a jewel in the roughAl3+ is a jewel in the rough
The if statement looks fine to me.
Try outputting the values of AutoSwitch3->Get() and limitSwitchB->Get(). Make sure something odd isn't going on.
cout << "Hello, robotics. Goodbye, world." << endl;
"The two-axis accelerometer provided in the kit of parts (shown in the picture below) is a two-axis accelerometer." - WPILib User's Guide
Unread 14-04-2010, 19:59
Digital inputs are pulled up (to a logic high... 1). When you short the signal line to ground the input will read as logic low, or 0.
Try doing
if(switch->Get() == 0) {...}
Unread 14-04-2010, 21:37
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Also make sure your wiring on the switches are correct.
We had a switch wired backwards, so every time it was triggered, it shorted the IO Board, causing all of our stuff to stop.
(And they blamed it on the programming!)
Unread 15-04-2010, 14:14
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
did that!
Autonomous Problem wakeboard.dude NI LabVIEW 3 26-01-2010 15:55
Autonomous problem railerobotics Programming 7 07-02-2006 08:36
Autonomous Problem... JoeFryman Programming 2 19-02-2005 14:56
PWM problem in autonomous outofcontrol Programming 5 27-02-2004 11:58
Autonomous problem. Code\\Pilot Programming 8 10-02-2004 19:40
