Go to Post And, if you don't know what something means, say so, we'll be happy to explain. - DonRotolo [more]
Unread 15-04-2010, 23:09
Re: Unexpected results from Encoder::GetRate()
Originally Posted by vamfun View Post
The scheme that I'm describing is a valid quadrature decoder in that it uses the B channel to determine direction.
No, it's just a counter with a direction input. It happens to work with a quadrature encoder if you don't have "noisy" rotation. If the encoder happens to oscillate a bit back and forth at the A channel transition, you'll get false counts.
That exact situation happened on our "Triple Play" robot. We had quadrature encoders on miniature omniwheel-ish rollers to track our motion on the carpet. We could watch the wheels not spin appreciably while the code told us they were making several revolutions. I fixed it by implementing a true quadrature decoder. Something almost exactly like my code was independently developed by Kevin Watson and incorporated into his Encoder.c library for the IFI controller.
[BB] An unexpected change in plans yodameister General Forum 22 01-12-2009 21:26
Inconsistent reading from encoder get rate rwood359 National Instruments LabVIEW and Data Acquisition 5 13-01-2009 19:10
Results from Drexel, thanks from 365. archiver 2001 1 24-06-2002 02:44
Results from GLR? archiver 2001 0 24-06-2002 02:44
results from regionals archiver 2000 0 23-06-2002 22:31
