Re: Multiple CAN networks
well, after digging through the code a bit more I found out that the interfaces to the CAN plugins are handled by the closed-source NetworkCommunication libraries. I think it is possible to bypass the libraries, however doing so will also most likely bypass the disable button for CAN jaguars.
There are two options. one, I can go forward with bypassing the networkcommunication backend and breaking the disable button and all watchdogs, or could you possibly change the cRIO-side jags to PWM mode and still do the networked 2CAN. |
I dont see where that would be an issue except with the closed loop control. The connection from the cRIO to the 2CAN sends data through UDP correct? Can we spoof it?
| Wireless Networks(A/B/G/N) | kiettyyyy | Rules/Strategy | 4 | 11-02-2009 15:04 |
| How Can Multiple Programmers Work on Same Project? | LVMastery | NI LabVIEW | 1 | 28-01-2009 23:43 |
| [FTC]: Multiple Programs or One Program with Multiple Auto Modes | kevin51292 | FIRST Tech Challenge | 4 | 02-01-2009 20:37 |
| Hosting multiple sites in multiple VMs | EHaskins | Website Design/Showcase | 6 | 22-12-2007 01:09 |
| Wifi Networks | Eugenia Gabrielov | Chit-Chat | 4 | 17-06-2004 09:56 |
