Go to Post I am sad that the Patriots lost, and I am happy for both teams that won...but I am even more thrilled that for the next two weeks robot building in the midwest comes to a standstill. ;) - Jessica Boucher [more]
View Poll Results: Swerve or Mecanum? Which does your team prefer?
Mecanum 26 24.53%
Swerve 49 46.23%
Neither, they are too complex and 4wd or 6wd will do the job 31 29.25%
Voters: 106. You may not vote on this poll
  #43   Spotlight this post!
Unread 16-04-2010, 23:22
Joining the 900 Meme Team
FRC #0079
Re: Mecanum or Swerve?
Originally Posted by joek View Post
then they must be using Fisher Price motors to drive, because we're only allowed 5 cims
Yes, many teams use the FP through an AM planetary to mesh with a CIM motor.
Originally Posted by artdutra04 View Post
I disagree. The first year 228 did swerve was the first year we won a regional.
There are exceptions, for some teams swerve works really REALLY well. Their drivers just get the hang of it.
Just to share a bit of a conversation I was having the other day, the problem with swerve drives is that the wheels are never in the direction you want to go. There is a slight delay. If the driver is aware of this and does not try to correct for it you will be fine. Otherwise you end up going in a bit of a circle. It takes some getting used to. Not a downside just a fact. If you decide to go with a swerve drive robot you need to build a practice bot so your driver can get the hang of it.
Swerve Drive DuskProgrammer Programming 7 16-01-2010 09:29
Swerve vs. Mech? yoshibrock Technical Discussion 24 15-01-2010 13:34
Swerve drive 4, 2+2? kirtar Technical Discussion 18 02-04-2008 06:58
Swerve Drivetrain Pelicano234 Technical Discussion 18 13-05-2007 12:55
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
