swerve drive alinement question
In a swerve drive system how do we know what direction our wheels are pointing when we start the bot, so the wheels are all facing the correct directions, I know with rotery encoders position is relitive to the starting position. I am sure that this is not a problem, because I have seen bots with swerve drive, so I know there is a solution, I just cannot find it.
Thanks in advanced for any help. Mark |
Re: swerve drive alinement question
We use the ma3 absolute encoders, the fact they're absolute means they keep the same 0.
We use Cherry magnetic sensors. If you look at the DEWBOT VI steering you can see the sensor mounted on the drive motor. There is a link on that page to the sensor specs.
There are three possible solutions:
1. add a set point, something like a microswitch being pressed when the wheel is at angle 0. For this solution the wheels would have to do an initialization process on the beginning of each match (turn around until microswitch is pressed). 2. Save your wheels last positions in the cRio memory, possible, but not really a good solution. 3. Third time's the charm - use absolute sensors (not incremental encoders) such as Potentiometers (one or multiple) or absolute encoders (see http://usdigital.com/ for MA3 or MAE3). have fun programming. Last edited by Or Makbily : 17-04-2010 at 11:18. |
1640 used the Cherry AN8 series absolute non-contact rotary sensors. We have been very pleased with the performance. Note that several teams have had problems with the US Digital absolute encoders. Several teams suspect electrostatic discharge to be the problem. The Cherry sensors are automotive qualified and IP67 rated. Perfect for our robot environment. The availability of the Cherry sensors is spotty and is a problem. Many other companies will be bringing absolute magnetic sensors to the market in the future. Robot teams should watch their development and possible robot applications. The potentiometer is loosing it's place on our robots.
We used one of the Kit Magnetic encoders for our swerve drive this year. They have a digital interface, so you can read them without any encoding error and without having to worry about calibrating the limits of an analog output to avoid a deadzone. You can get similar sensors with higher accuracy if you need it.
#9
potentiometers. We used them on our swerve drive this year, along with encoders on each of the wheel axles. That coupled with a MEMS gyro and good coding and a camera, and you can position yourself for nearly everything.
#10
Aside from electronic sensoring....
Many swerve systems, including Wild Swerve, have mechanical features that allow you to fine tune each module without tweaking your steering sensors. For instance, I have seen teams put radial slots in their steering chain mounts. The slots allow them to loosen their transmissions and make slight adjustments to the alignment, or compensate for chain that won't hit a center distance number and also line up properly. |
| Swerve Drive | DuskProgrammer | Programming | 7 | 16-01-2010 09:29 |
| Swerve Drive | Team1710 | Technical Discussion | 11 | 07-03-2009 09:58 |
| Swerve drive 4, 2+2? | kirtar | Technical Discussion | 18 | 02-04-2008 06:58 |
| A Swerve Drive Question | lndnny | Technical Discussion | 10 | 20-07-2006 08:09 |
| Swerve Drive | Jeff Waegelin | Technical Discussion | 14 | 17-09-2001 08:06 |
