Go to Post I am the person I am because I have come to accept the mistakes I have made, not because I try to change them. - IronicDeadBird [more]
Unread 17-04-2010, 09:55
mark.amber mark.amber is offline
FRC #2039
mark.amber is an unknown quantity at this point
swerve drive alinement question
In a swerve drive system how do we know what direction our wheels are pointing when we start the bot, so the wheels are all facing the correct directions, I know with rotery encoders position is relitive to the starting position. I am sure that this is not a problem, because I have seen bots with swerve drive, so I know there is a solution, I just cannot find it.
Thanks in advanced for any help.
Mark
Unread 17-04-2010, 10:34
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
Re: swerve drive alinement question
We use the ma3 absolute encoders, the fact they're absolute means they keep the same 0.
Unread 17-04-2010, 11:00
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
We use Cherry magnetic sensors. If you look at the DEWBOT VI steering you can see the sensor mounted on the drive motor. There is a link on that page to the sensor specs.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 17-04-2010, 11:14
Or Makbily Or Makbily is offline
FRC #2230
Or Makbily is an unknown quantity at this point
There are three possible solutions:
1. add a set point, something like a microswitch being pressed when the wheel is at angle 0. For this solution the wheels would have to do an initialization process on the beginning of each match (turn around until microswitch is pressed).
2. Save your wheels last positions in the cRio memory, possible, but not really a good solution.
3. Third time's the charm - use absolute sensors (not incremental encoders) such as Potentiometers (one or multiple) or absolute encoders (see http://usdigital.com/ for MA3 or MAE3).
have fun programming.
Unread 17-04-2010, 12:41
Gdeaver Gdeaver is offline
FRC #1640
1640 used the Cherry AN8 series absolute non-contact rotary sensors. We have been very pleased with the performance. Note that several teams have had problems with the US Digital absolute encoders. Several teams suspect electrostatic discharge to be the problem. The Cherry sensors are automotive qualified and IP67 rated. Perfect for our robot environment. The availability of the Cherry sensors is spotty and is a problem. Many other companies will be bringing absolute magnetic sensors to the market in the future. Robot teams should watch their development and possible robot applications. The potentiometer is loosing it's place on our robots.
Unread 17-04-2010, 12:50
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
Mark
Team 2423 used hall-effect sensors on our robot last year. When we turned on our robot, the wheels would spin until our sensors told us the wheels were facing forward.
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 17-04-2010, 13:23
Not all encoders are relative. Some are absolute, like the austriamicrosystems magnetic encoder that came with the 2010 KoP.
Unread 18-04-2010, 15:07
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
We used one of the Kit Magnetic encoders for our swerve drive this year. They have a digital interface, so you can read them without any encoding error and without having to worry about calibrating the limits of an analog output to avoid a deadzone. You can get similar sensors with higher accuracy if you need it.
Unread 18-04-2010, 18:55
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
potentiometers. We used them on our swerve drive this year, along with encoders on each of the wheel axles. That coupled with a MEMS gyro and good coding and a camera, and you can position yourself for nearly everything.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 18-04-2010, 20:35
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Aside from electronic sensoring....
Many swerve systems, including Wild Swerve, have mechanical features that allow you to fine tune each module without tweaking your steering sensors.
For instance, I have seen teams put radial slots in their steering chain mounts. The slots allow them to loosen their transmissions and make slight adjustments to the alignment, or compensate for chain that won't hit a center distance number and also line up properly.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Swerve Drive DuskProgrammer Programming 7 16-01-2010 09:29
Swerve Drive Team1710 Technical Discussion 11 07-03-2009 09:58
Swerve drive 4, 2+2? kirtar Technical Discussion 18 02-04-2008 06:58
A Swerve Drive Question lndnny Technical Discussion 10 20-07-2006 08:09
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
