Go to Post Any adult can open a door. Some can give direction. A few can give leadership. These are the true mentors. This is where true success comes from. - sanddrag [more]
Unread 18-04-2010, 15:41
masoug's Avatar
masoug masoug is offline
Food Consumer
FRC #0114
masoug is an unknown quantity at this point
Lightbulb Run Virtual cRIO
Hi,
I hope this is not a "stupid" question,but;
what would happen if one tried to run the cRIO image on a virtual machine (e.g. VMWare)? Would it even work?
Just curious.
-Masoug
JabbaScript
Unread 18-04-2010, 16:01
carrizzle451 carrizzle451 is offline
AKA: Alejandro Carrillo
FRC #0694 (Stuypulse)
carrizzle451 is an unknown quantity at this point
Re: Run Virtual cRIO
Not easily, since I don't think VMWare supports real-time OS's.
Unread 18-04-2010, 16:07
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Also, the cRIO is 2 processors: a 400MHz PowerPC CPU (what your code runs on), and an FPGA processor to interface with the modules. Your average emulator won't do that.
If you're looking for a way to test code without a cRIO, I think a special version of WPILib designed to run on a regular computer would work. The hardest part would probably be implementing the DS to robot comms protocol. A GUI robot control panel that allows you to set all the sensors and read all the outputs would be nice (labview comes to mind)
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 18-04-2010, 16:15
masoug's Avatar
Food Consumer
FRC #0114
Well i guess then we are stuck with the cRIO...
Anyway THANKS for the responses!
-Masoug
JabbaScript
Unread 18-04-2010, 23:31
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Here's what I would do:
Go into each top-level WPIlib VI, move the inputs and outputs far to the outside if possible, and wrap a Conditional Disable Structure around them, case on OS (VxWorks vs WIN) and put simulator code in the WIN case. If WIN, you can have a big global variables file for each type of IO (relay, PWM, DIO, Joystick, etc.) and do stuff. For the Comm loop, you could read a joystick and set the appropriate joystick data, as it is set in the existing comm code (except with USB joysticks on your computer instead). You could also throw in a Wait On Occurrence to the DS Occurrence (what gets passed into Start Comm) so the Robot Mode VI dosen't timeout (and a wait in there too so it runs at the normal speed or so)
Kettering Motorsports
Unread 18-04-2010, 23:44
JamJam263 JamJam263 is offline
FRC #0263
JamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of light
Well if your using C++ you could always use the wpi test harness. http://firstforge.wpi.edu/sf/project...b_test_harness
Favorite 2009 quotes:
"Do we really need all of the cRIO or can we cut it in half to save weight?"
cRIO wont run software ThisAintJeff NI LabVIEW 4 02-02-2010 15:47
How do you run the pneumatics through the CRio w/o using the Jaguars and the Spikes brreadd Pneumatics 3 20-11-2009 15:35
Robot Run 5K Run/Walk - fundraise or come for the fun Carol Fundraising 0 06-03-2009 16:14
DS tty serial and crio run speed Mr-Shutter FRC Control System 5 21-01-2009 12:39
cRio losing connection when "run as startup" mgurgol Programming 2 12-01-2009 12:18
