Go to Post Someone tried throwing out a perfectly good fleece blanket! It even had the quadratic formula on it! WHY ON EARTH WOULD YOU THROW AWAY THE QUADRATIC FORMULA?? - Karibou [more]
Unread 19-04-2010, 13:40
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
pic: 1671 Swerve Module
Unread 19-04-2010, 13:42
CraigHickman
Posts: n/a
Re: pic: 1671 Swerve Module
Originally Posted by steelerborn View Post
Slick! Care to answer some questions about your design? More specifically, why cantilever the belts, rather than put them inside the module? Also, I love the use of belts. When routed correctly, they outperform chain in both lifetime and torque transmission.
Also, a tip on top support crab modules: For FRC level contact, you might find yourself wanting more support on that top pivot. Even a single degree of deflection of the module makes you lose 90% of your contact patch on the ground...
Unread 19-04-2010, 15:12
FRC #5817 (Uni-Rex)
Thanks
I was actually thinking about putting the belt sprockets on the inside of the module. But I then thought that having them on the outside will allow easier access to the belts. We have never used belts before does it matter how easy they are to access?
Good enough is the enemy of anything great!
team 1671
Unread 19-04-2010, 15:16
martin417's Avatar
martin417 martin417 is online now
Opinionated old goat
AKA: Martin Wilson
We used belts exclusively this year, and even though we had some slippage during shoving matches and bump crossings, we never had to replace a belt, and no visible wear occurred. So no, I don't think you need access.
Former Mentor Team 1771
Former mentor Team 4509
Unread 19-04-2010, 15:24
FRC #5817 (Uni-Rex)
Okay, thank you guys.
I will modify the cad today it is a pretty quick fix.
team 1671
Unread 19-04-2010, 16:10
CraigHickman
Posts: n/a
Thanks
As long as it's properly tensioned, the system should be fine. However, properly tensioning and aligning belts can a bit of a dynamic situation when in FIRST. Constantly flexing frames can lead to sudden losses or gains in tension, unless you can design a quite rigid chassis.
I really dig the direction you're heading in, so keep it up! A Belt drive crab isn't common, and if you can pull it off it ought to yield some nice weight advantages.
Unread 19-04-2010, 17:27
FRC #5817 (Uni-Rex)
Yeah I have wanted to use belts for quite some time now. But we were nervous about starting it without testing so we waited for the offseason to come around.
Yeah a weight advantage is always good to have.
team 1671
Unread 19-04-2010, 18:39
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Looks nice! Is it based on the 118 swerve modules (or 221's "Revolution Modules")?
If you're going to run a swerve with belts, you should look into 1717's 2010 machine:
They might be able to give you some advice on it.
You said this is for an off-season project? Can't wait to see the final version(s)! Remember to post pictures, and good luck with it.
Edit: One more thing. For an off-season project, this probably won't matter, but for a competition robot, if you have the machining capabilities, time, and budget, you should probably replace those shaft collars with snaprings. Those setscrews have a nasty habit of coming loose at the worst possible times, and snaprings take up a heck of a lot less space and weight, too.
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 19-04-2010, 18:56
FRC #5817 (Uni-Rex)
Yeah I looked at the revolution first but wanted to change some things, mainly the use of chain.
1717 does have an awesome swerve I was talking to them about it at the la regional. Our overall base however is using 3 wd in place of the usual 4. So this cuts the weight of a whole module.
I will definitely look into that thanks for the tip.
And yes we will post more pics as time goes on.
team 1671
Unread 19-04-2010, 19:07
Nice. Keep up the good work.
One more thing I just remembered. I can't tell from the picture, but do you have thrust bearings/bushings in place to distribute the thrust loads from those miter gears? Since the gears are working at an angle, there will be a significant thrust load along their axes. If you don't have a bearing/bushing in place to handle this, you can end up damaging parts very quickly. We found this out the hard way in our worm drive kicker gearbox this year. If you go to the 221 website and take a look at the close-ups of the Revolution (or download the CAD file), I believe you can see the thrust bushings implemented correctly.
Unread 19-04-2010, 19:12
FRC #5817 (Uni-Rex)
Yeah it is hard to tell from the picture, but yes there is bearings in place for that purpose. The angle makes it difficult to tell.
team 1671
Unread 19-04-2010, 19:15
Chris is me's Avatar
AKA: Pinecone
Any thoughts on replacing the timing belt on the outside with gears, perhaps even with a slight reduction? I imagine that would be a little easier to maintain.
Unread 19-04-2010, 19:23
FRC #5817 (Uni-Rex)
Yeah I had looked into that too. I went and looked at 148's swerve system from 2008 (tumbleweed) they used gears on the outside too. But in the end I realized that it really wasn't the direction I wanted to head (light weight module). So I talked with my mentors and they brought up timing belts and showed me a great site for belt parts. But the module frame remained the same.
team 1671
Unread 20-04-2010, 02:21
FRC #5817 (Uni-Rex)
Okay
I finished the changes on the module tonight and uploaded the new picture. It should be up soon. Thank you guys for all your help.
team 1671
Unread 20-04-2010, 08:49
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
During 118's Crab Module Lecture in 2009, they suggested making the reduction after the miter gears as large as possible in order to reduce the amount of torque transferred through the miter gears. This prevented them from slipping under heavy load due to the slightest misalignment. It may also make the gearbox lighter since you might only need a single reduction coming out of it.
GitHub
pic: Swerve Module Concept (View 1) Dave McLaughlin Extra Discussion 15 16-06-2009 22:36
pic: FRC 1771 Swerve Module sdcantrell56 Extra Discussion 17 13-04-2008 00:36
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
