Go to Post As far as I am concerned, the quality of an electronic device is directly proportional to the number of blinky lights on it. - EricVanWyk [more]
Unread 19-04-2010, 16:28
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
2010 Lesson Learned: The Negative
What could have FIRST done better this year?
Unread 19-04-2010, 16:42
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: 2010 Lesson Learned: The Negative
NO GAME OBJECT IN THE KIT OF PARTS!
FIRST never do this to us again! The surface finish on the balls was so specific at driving the design of ball handling mechanisms and you screwed it up again by chosing something we couldn't get and not warning the manufacturer to stock up because a huge influx of orders would be coming.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 19-04-2010, 16:43
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Truthfully? As far the game goes, my only REAL complaint was the DOGMA system. Ok idea, bad implementation. Should have been 1 point penalty once per ball, not repeated penalties.
Unread 19-04-2010, 16:59
Jared Russell's Avatar
Taking a year (mostly) off
Peter and Tom just addressed #1 and #2 on my list.
I would like to see a stronger incentive for using the camera (and autonomous mode in general).
The Classmate is at best a work in progress. Between Windows startup times and power management woes, battery life, USB enumeration issues, powering the USB ports, cheapo Ethernet ports, and the tedium of "FMS Locked" and E-stop, I think we can do a lot better.
Unread 19-04-2010, 17:02
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
This wasn't completely FIRST's problem, but the discontinuation of the WGA bridges and their replacement with the WET bridges was a bit of a problem that could have been avoided by some more testing on FIRST's part to make sure there weren't any major problems with it (long connection times, disconnecting WGA bridges, etc.)
EDIT: agreement with most of the stuff with the classmate on the above post
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 19-04-2010, 17:03
Tom Line's Avatar
Add in the impossibility of getting replacement parts like batteries for the classmate to that list.
Unread 19-04-2010, 17:18
zman2865 zman2865 is offline
(The Game)
FRC #2865 (Roboteknix)
zman2865 is an unknown quantity at this point
Re: 2010 Lesson Learned: The inspectors
Ok first of all i'm going to say i appreciate all the volunteers that helped out with FIRST FRC robotics this year and every year, but i think that FIRST needs to have a code of conduct for when it comes to inspecting a teams robot. For example having to ask to move your robot at ANY and EVERY time they wish to do so, ect. the reason i say that is because this year when we went to Atlanta we missed our very first match because during our teams inspection the inspector moved our robot while it was off while this doesn't seem like a problem it is because our team decided to use CAN this year and when he moved our robot he sent reverse current into our jaguars thus completely ruining functionality of 3 of our jaguars it was to bad that the only thing the texas instruments guy could do for us was give us three new jaguars(after 30min. of trying to fix them. on top of the at least 1 hour inspection) and after that things just went down hill for our team.
Unread 19-04-2010, 17:21
The Cyborg's Avatar
The Cyborg The Cyborg is offline
That Awkward One
AKA: Mary Soltis
FRC #0051 (Wings of Fire)
The Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant future
I didn't like the many field problems experienced at the competitions. Sometimes matches get delayed for 10-20 minutes because of these problems. The Kettering District competition lasted until 7:00PM because of the many field issues that needed to be worked on. I know the system had to be rebooted a few times, but each of those reboots took up to a half hour each! FIRST or National Instruments needs to find a way to make problems like these quicker to solve and fix to make things run smoother.
I also didn't like how it is hard to figure whether or not it is a field or a robot problem when a robot doesn't run during a match. There needs to be a system in place that determines functionality of both the field and the robot to better determine where the problem is coming from.
Unread 19-04-2010, 17:24
efoote868 efoote868 is online now
foote stepped in
AKA: E. Foote
FRC #0868
I didn't like that we have to reuse control systems from a previous year. *thinks about the pile of robot skeletons in the closet*
I didn't like the no-bonus autonomous.
I didn't like the low scoring matches.
I didn't like how the game wasn't conducive to defense.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 19-04-2010, 17:27
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
I dont like the seeding system. Although, next year, with a new game, I hope for a new seeding system more like elims.
EDIT: Suspension. With only about 5 total in the season, it was a completely failed game mechanic.
Unread 19-04-2010, 17:34
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
It looked to me like some robots at the championships had issues (weight, electrical, pneumatic) that needed to be fixed but passed inspection at the regionals. I don't think they're doing teams a favor by letting them through regionals this way. Maybe they can issue conditional inspection approvals to let teams compete but all issues need to be corrected before the eliminations. That way teams earning their way to Altanta would be confident they are good to go.
Unread 19-04-2010, 17:43
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
We've moved our robot with the power off many times without any damage to our Jaguars (and yes, we were using CAN). Now, it's possible that there was some sort of electro-static discharge (ESD) event that propagated through the CAN bus that caused multiple Jaguar failures. I defer to Al Skierkiewicz (CMP Lead Robot Inspector, and VERY familiar with the robot control system electronics) as to whether back-EMF could induce such a problem.
As far as robot inspector code-of-conduct goes, the inspectors at CMP were presented with a huge challenge: get 340+ robots inspected in less time than what is allotted for most regional events. If your inspector seemed a bit rushed, it's because we all were. If you felt uncomfortable moving your robot, you should have said so. I will only touch a robot when looking for sharp edges, tracing wires, or inspecting bumpers. If someone asks me to help support their robot, hold a component, or move a mechanism, I'll do it because I trust the team will not ask me to do something that is unsafe. No inspector would ever want to damage a team's robot. We all want to see everyone compete safely and within the rules.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 19-04-2010, 17:47
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
A picture paints a thousand words. Here are two pictures that express my biggest negative this year.
There was a lot of this........
shortly followed by a whole lot more of this........
Hurry up and wait....and wait....and wait.......
Maybe we can have custom built for FIRST WiFi next season.
Unread 19-04-2010, 17:48
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
Sort of a follow up to the DOGMA issue before. It was a real problem when a ball would fall off the ball-return track (before passing through the counter) and a reset-volunteer would pick it up and place it back in the mid field (A rare occasion, but I still saw this happen more than once). This obviously potentially would ruin a match for the alliance. So my suggestion would be better volunteer training for those special cases as described.
Unread 19-04-2010, 17:52
I completely agree with you. There were several inspection "faults" that should have been caught and corrected at the regionals. These problems were identified and corrected at CMP at the cost of considerable stress to the teams and the inspectors.
I also don't think teams should be held off the field at regionals for minor discrepancies, but the teams should be forced to correct such problems before the elimination rounds. The pre-elimination round weight check should indeed include a check for any conditional "passes" and verification that the problem(s) are resolved.
2010 Lesson Learned: The Positive Koko Ed General Forum 37 21-04-2010 16:42
Lessons Learned - The Negative Koko Ed General Forum 221 25-04-2009 16:40
Lesson Learned: The Negative Koko Ed General Forum 98 07-05-2008 20:32
Lesson Learned: The Positive. Koko Ed General Forum 24 21-04-2008 13:11
Lessons learned 2005: The negative Koko Ed FRC Game Design 138 06-05-2005 18:58
