Go to Post It's important to know that it isn't always best to have biggest machine out there. - Quatitos [more]
Unread 20-04-2010, 00:40
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: 2010 Lesson Learned: The Negative
What would be nice is some quick and efficient way to reprogram a radio to work with a test field setup. Having an alternate SSID transmitter on the practice field would work great. Running a test FMS setup isn't that hard to do (laptop w/ basic FMS + wireless router (needs to be copy of field one or similar to handle encryption though) + ethernet switch = full system). If the robot works just fine on that field, the problem must be specific to some different element of the field FMS. It also means a place where you have plenty of time to debug and also look at the hidden information such as packet latencys.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
2010 Lesson Learned: The Positive Koko Ed General Forum 37 21-04-2010 16:42
Lessons Learned - The Negative Koko Ed General Forum 221 25-04-2009 16:40
Lesson Learned: The Negative Koko Ed General Forum 98 07-05-2008 20:32
Lesson Learned: The Positive. Koko Ed General Forum 24 21-04-2008 13:11
Lessons learned 2005: The negative Koko Ed FRC Game Design 138 06-05-2005 18:58
