Go to Post Students dream up the ideas for bots, it is than up to the mentors and engineers to make these dreams a reality. - dddriveman [more]
Unread 20-04-2010, 10:58
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Re: Crab/Swerve Drive Module Attachment Point
Team 228 should be posting their SolidWorks model very soon for this year's robot. Our mounting was to capture the swerve module surfaces between two 0.25" Delrin bearing plates mounted to the robot frame. It took quite a few man hours to get the bearing plates to run flawlessly, but it was worth it. This connection system worked very well for us this season with no failures.
The bearing surfaces had quite a large OD in anticipation of the cantilevered stress from climbing the bumps and playing heavy defense. On a flat playing field we'd probably go with a much smaller bearing surface.
We did not do full concentric swerve. There are measurable efficiency losses in using bevel gears which we didn't feel were offset by the ability to spin a drive pods continuously. Our swerve pods were fully independent allowing us to rotate while driving in a straight line (there's a white paper here on CD covering independent twisting swerve).
We used a three axis joystick and gyros for field-centric control. The third axis (joystick twist) allowed for the rotate while driving in any direction.
The swerve system had a pretty steep learning curve for us. I would definitely recommend prototyping during the off-season to avoid some of the stress that we encountered.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Crab/Swerve Drive wheel rotation issues DavidGitz FRC Control System 5 30-01-2010 10:25
Questions about crab/swerve drive. BenX02 Technical Discussion 62 28-04-2009 20:38
Crab / Swerve drive joystick control scheme Tom Line Programming 12 16-04-2007 18:47
Inexpensive crab module? Jeremiah Johnson Technical Discussion 20 24-04-2006 17:10
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
