Re: Picking a gyro for field-centric swerve control
We used a vector-based system for our drivetrain this year. We used an X and Y gyro to calculate our first vector, and joystick data to calculate the second. By using wheel encoders rather than the joystick data, theoretically you should get a vector that would be more useful in getting absolute position. (We were only compensating for drifts in the joystick and the tenancy of the wheels to drift.)
Of course, redundancy is good. finding the average value of these, we were recording a 1.8% Margin of Error throughout the CT regional and a 2.1% in Atlanta. While not perfect, it's certainly better than we expected, as we know that our gyros had a 1% drift on the X axis and an 8% drift on the Y. (Found by graphing signal over 100 reads on a stable surface.) |
You lost me there; did you mean X and Y accelerometers? If you really did mean gyro (meaning yaw rate gyro), what axes did X and Y correspond with? Z seems to be the only one of interest...
One was mounted as documented on the X axis, while the other was oriented 90 degrees to the X, on the Y axis (we used that to do an inverse-pendulum system, so we could balance and travel across the bump)
| pic: DS Swerve on the field | Racer26 | Extra Discussion | 15 | 09-04-2010 21:34 |
| Steering control without a gyro | nathanww | C/C++ | 4 | 27-01-2009 12:14 |
| Crab / Swerve drive joystick control scheme | Tom Line | Programming | 12 | 16-04-2007 18:47 |
| Swerve drive control system | dpick1055 | Programming | 8 | 22-01-2007 19:06 |
| Omni-wheels and driver-centric drive | efoote868 | Programming | 10 | 01-11-2006 22:22 |
