#14
Re: Picking a gyro for field-centric swerve control
Three unpowered omniwheels in a "kiwi" configuration (as the sides of an equilateral triangle, e.g. at 120 degree angles to each other).
An encoder on each wheel. The entire assembly on a suspension to ensure that it never leaves the ground (assuming a flat-ish field). Such an arrangement would theoretically give you drift-free position and velocity in R2, and would be robust to collision (as long as the wheels don't leave the ground). |
| pic: DS Swerve on the field | Racer26 | Extra Discussion | 15 | 09-04-2010 21:34 |
| Steering control without a gyro | nathanww | C/C++ | 4 | 27-01-2009 12:14 |
| Crab / Swerve drive joystick control scheme | Tom Line | Programming | 12 | 16-04-2007 18:47 |
| Swerve drive control system | dpick1055 | Programming | 8 | 22-01-2007 19:06 |
| Omni-wheels and driver-centric drive | efoote868 | Programming | 10 | 01-11-2006 22:22 |
