Go to Post I urge them to build the kitbot and repeateadly smash it into a concrete wall in order to sate their anger. It will soon wane when they manage to do more damage to the wall than to the kitbot. That is honestly the reason that we ended up using the kitframe this year. - Andrew Blair [more]
Unread 28-09-2002, 22:46
R Bohannan R Bohannan is offline
#0166 (Chop Shop)
R Bohannan is an unknown quantity at this point
Send a message via AIM to R Bohannan
Chiaphua gears
Does anyone have any spare Chiaphua gears that we can beg, borrow, steal, or barter? We have now destructed about 6 of those "indestructable" beasts.
"One person's impossible task is another's opportunity for glory"
Team 166
The Chop Shop (New Name)
Holders of the "Wrench"
Unread 29-09-2002, 00:14
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
are you talking about the small gold colored ones?
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 29-09-2002, 00:20
#0166 (Chop Shop)
Yes, the ones that mate with the output shaft of the Chiaphua.
Team 166
Unread 29-09-2002, 14:36
RBrandy RBrandy is offline
AKA: Ryan
#0093 (NEW Apple Corps)
RBrandy is a jewel in the roughRBrandy is a jewel in the roughRBrandy is a jewel in the rough
Send a message via AIM to RBrandy
ill see if we have any... im not promising anything
Team 93 Alumini
Unread 29-09-2002, 14:55
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
How the heck did you destroy them?
Unread 29-09-2002, 15:56
Roboticsrob
i'm not sure how you could really destroy those. perhaps you have some gear ratio problems in there, might wanna check it out before you start using a new one
Unread 29-09-2002, 20:36
#0166 (Chop Shop)
Let's see.
We lost No. 1 at regionals when we bent a shaft. The gear that mates with the Chiaphua gear took out about 1/4" of the teeth.
We lost No. 2 and 3 during the same match when we broke the shafts that the Chiaphua gears were mounted on. The mating gear again chewed up the Chiaphua gears.
I don't remember when/how we lost Number 4, but it was a similar situation.
Numbers 5 and 6 are on our robot now, but are badly mangled.
If we can find some of these beasts, we'll post some pictures of our "handiwork".
Team 166
Unread 29-09-2002, 21:33
AKA: Ryan
how are the shafts on the bot doing now? cause if they are still bent, the way im seeing it, ur gonna break every gear we give u
Team 93 Alumini
Unread 29-09-2002, 22:21
Roboticsrob
could there possibly be some way you can prevent these shafts from bending? it sounds like there could be some strange design in your drive system that it doesn't like when you put any type of force on it, i had never heard about these gears breaking before, but i guess anything can happen
Unread 30-09-2002, 08:46
#0166 (Chop Shop)
The current shafts are fine now. In fact we redesigned the whole transmission. The flaw (lesson learned) from the old transmission is that we used 3/8" shafts. The new transmissions are using 5/8" shafts and are working fine.
There's not enough space on the server to list all the shafts we bent this year. The most frustrating part is that it all started when, during the heat of battle at UTC, someone forgot to install the mounting screws on one side of one transmission. That transmission then torqued and bent the output shaft. Causing a very unfortunate chain of events.
We learned a lot this year...
Team 166
Unread 01-10-2002, 20:37
#0166 (Chop Shop)
Many thanks to team 151 who has graciously provided us with two gears. Thanks all.
Team 166
Matching Drill and Chiaphua sanddrag Motors 12 17-01-2003 11:23
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Chiaphua Drivetrains sanddrag Motors 9 13-08-2002 12:25
replacement gears joni_m Technical Discussion 1 22-01-2002 18:01
