Go to Post I say: Chutes & Ladders in FRC 2008! - petek [more]
Go Back   Chief Delphi > Technical > CAD
Unread 21-04-2010, 18:18
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Help with CNC machining STL file - MasterCAM X
I have an STL file I'd like to machine as a 3D relief using MasterCAM X. I want this shape to pop out of the surface when it is all done, so I need to machine down around the shape. I've been able to do that, but I have not been able to machine down the surrounding surface. It only goes as far as the shape. Any tips? I have been able to get the STL into a 2D projection DXF, but I'm having problems getting just the outline to contour around, and problems with the chains not being continuous or something. If anyone is good with this stuff, I'd be glad to send the file your way. Thanks.
Unread 24-04-2010, 15:32
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Help with CNC machining STL file - MasterCAM X
I'm not an engineer, but I'm going to assume that you're using a mill to do this. Wouldn't it be possible simply to machine down around the shape manually? After all, the shape's been cut out already.
Unread 24-04-2010, 17:18
What about importing the STL into Solidworks, adding a clear area around it, and then exporting it again into what ever format you want?
Unread 24-04-2010, 17:25
That's not a bad idea. Didn't think of that. I might give that a try. Thanks.
MasterCam, Solidworks & CNC Help R.C. CAD 9 09-11-2008 23:03
Machining plastics with CNC Ben Mitchell Technical Discussion 14 13-03-2007 14:01
Help! making an inventor file into an autodesk file kjhobin Inventor 5 19-03-2006 23:04
help with 06 denso motor cad file Jim Schaddelee SolidWorks 3 29-01-2006 22:37
just wondering [g code cnc machining] [527]phil Technical Discussion 16 17-10-2004 17:21
