Go to Post We draw the line when our students are more affectionate towards the tools rather than eachother. - ksafin [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 29-09-2002, 13:24
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
Question New Line Input Parsing
Well, as everyone knows, not everyone knows how to use the <br> tag when posting on a website, and that is my problem. I want to have my input be automatically parsed when you hit enter
to get a new line like this. I've been looking round the web and haven't found any info on how to do this. if anyone has any insite you help would be gratly appriciated.
p.s. Brandon, why do you have the spell checker commented out in the source for pages? does it not work?
Where has all the fun gone?
Unread 29-09-2002, 16:13
Happy Birthday! rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Where are you trying to do this? In a form? In an WYSIWYG editor? Either way, new lines are normally denoted by a '\n' character, if that helps any.
Unread 29-09-2002, 16:22
Trashed20's Avatar
im talking about text box input through html forms, like the ones used to post these messages. For example you hit enter 3 times you would get spaces in the text, but i need to convert that to \n or <br> tags
Unread 29-09-2002, 20:15
Joel J's Avatar
Joel J Joel J is offline
do you..
Well, if the script parsing the HTML form is written in PHP, you can simply use the nl2br() function. Lets say the textbox input is saved to the variable $info. To convert all the newline characters present in it, you would do:
$info = nl2br($info);
Otherwise, you could do some sort of regex command. Post some more information if the script isn't written in PHP.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 29-09-2002, 20:30
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Joel suggested the correct PHP function.
To do it in PERL, you could do this:
  $someText =~ s/\n\n/<p>/g;
  $someText =~ s/\n/<br>/g;
And, to answer your question about the spell checker.
vBulletin has it commented out by default, because I believe the service they were using started to charge people.
They just leave the code there in case you want to pay for the service, I think.
Brandon Martus
e-mail
Unread 29-09-2002, 22:08
Trashed20's Avatar
thanks, i prolly should have said that i was using php.
Vbulletin make you pay for everything now doens't it. how much is a liscence up to now?
Unread 30-09-2002, 10:46
busy.
AKA: B. Slash Kamen
vBulletin doesn't make you pay for the spell checker, the spell checker service makes you pay for it.
vBulletin is $35/yr, which really isn't that bad for such a powerful piece of software that is continually updated, and fully customizable.
Brandon Martus
e-mail
Listen-to xml parsing example thingie Trashed20 Website Design/Showcase 4 27-03-2003 15:13
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
iParts on firstcadlibrary.com Ed Sparks Inventor 3 08-01-2003 23:30
approach to autonomy Mike375 Programming 32 08-01-2003 14:04
emulationFIRST v0.04 Matt Leese Programming 7 09-07-2002 08:54
