Go to Post But you are an influencer: Use it for good. - DonRotolo [more]
  #34   Spotlight this post!
Unread 22-04-2010, 12:13
IBdrummer's Avatar
IBdrummer IBdrummer is offline
AKA: Beau Muniz
FRC #5492 (Winners Circle Robotics)
IBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of light
Re: Curie Match 100, 28-0
Originally Posted by George1902 View Post
Solution: Give the losing alliance their own score in seeding points. Additionally, you may want to add a portion of the winner's score to the loser's seeding points to factor in strength of schedule. One possible formula for the loser's seeding score is S = L + 1/2*W.
Solution: Make sure the winning alliance isn't rewarded better for the loser's score than they are for their own. One possible formula for the winner's seeding score is S = W + L.
If you run an off season event, try to tweak the ranking system a bit instead of making a knee-jerk switch back to the W-L-T method. I think FIRST is on to something here, it just needs some refinement.
You make a good point. I think it running in the off season could show FIRST that it is a good ranking system (if it works). I liked this years system (ignoring the 6v0 problem) because it places winning as a priority but focuses scoring and competition more than W-L-T record. Getting one bad match up would completely ruin your record previously and this year helps reduce that impact. Not to mention the system is much easier to understand. before this year I didn't know what we needed to do in a match to rank up, this year its clear cut. We need to gain x# of seeding points in this match in order to move up a rank.
4 Match Finals & Biggest Tie Match akeisic Regional Competitions 19 30-03-2010 19:26
pic: Sum of team numbers versus match number in Curie Kris Verdeyen Extra Discussion 28 27-04-2008 15:09
Spring pulling before match or while in match?? Bomberofdoom Technical Discussion 3 11-01-2007 08:03
CURIE!!!!!!!!!!!! xzvrw2 Championship Event 91 03-05-2006 21:46
Pre-Match/Post- Match Pit Routine Mark_lyons General Forum 14 31-03-2002 15:19
