Go to Post I can't believe I let build season distract me from the fact that iHop had unlimited pancakes for a few weeks. - IronicDeadBird [more]
Unread 28-09-2002, 01:06
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Finally, a fully working emulator!
Well, I finally finished it, even though it's more than 2 months past my goal. My PBASIC emulator now supports every command I know of (except debug), including multiple program slots. The GUI is fairly easy to use and gives clear output.
Anyway, it should be in the whitepapers section soon, but until then, it is available, as always, at my website:
http://FIRSTprograms.tripod.com
Check it out and let me know what you think!
(While you're there, take a look at its counter-part, the graphical program generator.)
Unread 28-09-2002, 02:19
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Ehh... still majorly buggy...
Gave me an error when I loaded my robot code. CON30 does not exist... then the program crashed...
*shrugs*
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 28-09-2002, 10:06
could you send me your code? I haven't run into anything like this, so I'd like to check it out.
[edit]
never mind... your code is the Toborov stuff posted earlier, right? The problem came from my parser thinking the CON ins CASTER_CON was an actual command. It should be fixed withing a few minutes.
[/edit]
Unread 28-09-2002, 18:31
ok, its fixed. Download the newest version here
Unread 28-09-2002, 22:00
Jeremy Roberts's Avatar
Jeremy Roberts Jeremy Roberts is offline
Coach 4026
FRC #4026 (Global Dynamics)
Jeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant future
Send a message via AIM to Jeremy Roberts
Great job! I'm sure as other programmers see this and give their feedback it will only get better.
Jeremy Roberts
GeorgiaFIRST Planning Committee | Peachtree Regional
Georgia Tech RoboJackets FIRST Co-Founder
Engineer/Mentor 4026
Former teams: 132, 608, 832, 1002, 1848
Unread 29-09-2002, 00:49
Thank you. That is exactly my intention in releasing it here first. Can I assume that it worked properly with your code, too? I always here about the people it doesn't work for, but I also like hearing some of the success (it keeps me sane after coding for 18+ hours straight).
Unread 29-09-2002, 07:17
Mike375's Avatar
Mike375 Mike375 is offline
#0375 (Robotic Plague)
Mike375 will become famous soon enough
Send a message via AIM to Mike375
Smile ::gives you pat on the back::
I was trying out your Robo-emulator last nite and had no troubles running our program from last year. I am highly enthusiastic about using during next year's build. Finally I'll have a way to resolve all the shouting matches (j.k) between the people who blame the code, and the people who blame the subsystems (btw, never the code). Thanks again.
-Mike 375
Unread 29-09-2002, 17:56
Glad to hear it.
Does anyone have any multi-program (as in RUN command) programs? I've created some test-cases, but I'd like to hear whether it works on real code. I can't see any reason why it wouldn't, but its the one feature that I can't fully test on my own.
Unread 29-09-2002, 22:10
Coach 4026
It work fine on our program.
Jeremy Roberts
Unread 29-09-2002, 22:16
Good. I just realized that when my laptop crashed a while back, I lost the Lookup/Lookdown code, but I'll put it back in sometime later tonight (whenever I finish my physics lab report and a few other projects).
Unread 01-10-2002, 01:14
Well, time went by faster than I thought, so the new code won't be up until sometime tomorrow evening. I just finished adding support for real Joysticks via DirectX 5, but haven't had a chance to test it fully.
Anyway, I'll post an update as soon as I'm done.
Whose working this summer? Frank(Aflak) Chit-Chat 20 28-05-2003 11:35
RoboEmu v.1a (another PBASIC emulator) rbayer Programming 0 07-07-2002 00:45
emulationFIRST (aka PBasic emulator) Matt Leese Programming 5 30-06-2002 12:06
Need list of feature for PBASIC emulator. rbayer Programming 37 20-06-2002 16:17
Is there going to be a PBasic emulator out there?? Matt Attallah Programming 7 14-12-2001 13:20
