Go to Post Patience, grasshopper. They'll get to it. - Rick TYler [more]
Unread 22-04-2010, 14:47
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
pic: 1671 swerve module 2.0
Unread 22-04-2010, 14:53
AdamHeard's Avatar
Lead Mentor
Re: pic: 1671 swerve module 2.0
You really should post your interface with the frame, that has a much bigger effect on performance than what is shown here.
Also, those aren't snap rings and probably won't hold.
Unread 22-04-2010, 15:01
What you want are snap rings or E-rings.
We like snap rings. http://www.mcmaster.com/param/images...a189-120px.gif
Unread 22-04-2010, 15:22
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Yeah. E-rings are quicker to install and don't require a special tool, but snaprings are more secure.
Otherwise, this looks great! Very compact and light. Is there now a belt sprocket reduction inside the module like JesseK suggested?
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 22-04-2010, 15:27
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
me's likum 10-32s and washas
mike d
See Ya
Unread 22-04-2010, 16:56
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I'd recommend you just get rid of snap rings altogether if you have access to a lathe. Lathe out and tap the ends of each shaft for a #10-32 or #8-32 bolt and use a thread locker. We did that for the first time this year on a couple of rods for the kicker and not only were they very robust they also look pretty sharp.
GitHub
Unread 22-04-2010, 17:15
Chris is me's Avatar
AKA: Pinecone
Would that work with both axles being live?
Unread 22-04-2010, 17:16
AdamHeard's Avatar
Lead Mentor
You would need a lathe to make snap ring grooves, and it's really not difficult at all (several of my students can whip they out real fast).
Snap rings are lighter, quicker to change (one of my kids is a ninja with snap ring pliers, can change a wheel out in like 12 seconds total), and require less machine time than tapping the ends.
And for anything that rotates, I've found end tapping has a tendency to back out, even with threadlocker. It may take a long time to, but it's just a risk you don't need to take.
It would work, but is less secure than snap rings.
Unread 22-04-2010, 17:57
FRC #5817 (Uni-Rex)
Wow a lot of questions to answer.
Okay this is actually about 3 days old now.
and I fixed a lot of the concerns after doing a little more research on swerves as well as watching the robonauts conference.
Now the clips are gone. And replaced with bolts on the ends using a lathe on the shaft.
Also thrust bearings were modified to fit with the base.
The wheel is connecfted with the belt sprocket so the bottom axel is dead.
I will post the new one now that the version 2.0 is up.
I will also show how it connects with the base.
Thanks I really appreciate you guys helping me out with this.
Good enough is the enemy of anything great!
team 1671
Unread 22-04-2010, 18:38
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
If the axle is dead, you could use a steel pipe instead of a solid shaft. Then, you could tap the ends and put a bolt in. We use this method on all of our dead-shaft drivetrain applications, in either 3/8" or 1/2", depending on the stresses. Most years we use all 3/8", except this year we used 1/2" on some of the wheels to handle the bump better. This is very similar to the method above, except you wouldn't need to lathe the end out of the shaft
Kettering Motorsports
Unread 22-04-2010, 18:41
FRC #5817 (Uni-Rex)
Thanks for the tip. That is a quick cad fix.
team 1671
pic: 1671 Swerve Module steelerborn Extra Discussion 14 20-04-2010 08:49
pic: Swerve Module Concept (View 1) Dave McLaughlin Extra Discussion 15 16-06-2009 22:36
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
