Go to Post Given how easily these things pop, is "Blow Out Pricing" really the best choice of words? - ahecht [more]
Unread 23-04-2010, 14:05
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
pic: 1671 swerve module 3.0
Unread 23-04-2010, 14:07
CraigHickman
Posts: n/a
Re: pic: 1671 swerve module 3.0
Looking good! I'm digging the iterations you're going through here. Constant design improvement is something to be proud of.
Out of curiosity, do you think you'll need any sort of tensioner on the lower belt, or will it be robust enough to hold without one?
Unread 23-04-2010, 14:09
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
If you set the center to center distance correctly then you shouldnt need a tensioner, especially considering kevlar reinforced belts essentially do not stretch, especially during a typical first season. The only thing that could be a benefit is some type of idler to effectively increase the wrap around the small pulley. As it is now, with sudden direction changes you could skip the belt
Mentor 2415
Unread 23-04-2010, 15:27
CraigHickman
Posts: n/a
I have seen/stretched Kevlar belting in FIRST. The only belts that I have worked with and not stretched are steel belted Brecoflex belts. From this experience, I would feel safer with some kind of tensioner. Something as simple as a milled slot with a busing mounted idler could do fine.
Unread 23-04-2010, 15:52
FRC #5817 (Uni-Rex)
Thanks
Yeah we have never used belts before. So if idlers are needed I will put them in.
Good enough is the enemy of anything great!
team 1671
Unread 23-04-2010, 16:39
angelawence11's Avatar
angelawence11 angelawence11 is offline
FRC #0195 (Cyber Knights)
Team Role: CAD
angelawence11 is an unknown quantity at this point
very nice. they look much simpler and lighter than our swerves from 2009!
Unread 24-04-2010, 15:38
CraigHickman
Posts: n/a
Originally Posted by steelerborn View Post
Thanks
I wouldn't say needed, but having more controls over a possible failure point is rarely a bad thing.
Also, I like your method of integrating the frame plate as a pivot surface for the module. Quite slick.
Unread 24-04-2010, 15:45
FRC #5817 (Uni-Rex)
Thanks a ton for your guy's help.
Ursa engineering and I really appreciate it.
I think we are about ready to start phase two. I am almost done with the total cost of the prototype. Then we will start ordering and punching out the parts. I will be posting pictures of the final system when it is complete.
team 1671
Unread 24-04-2010, 15:49
AdamHeard's Avatar
Lead Mentor
is that pink piece the only thing supporting the module?
Unread 24-04-2010, 15:53
FRC #5817 (Uni-Rex)
No it is supported there and also on the frame where it is mounted. It has 2 thurst bearings 1 inch apart with a spacer in the middle.
team 1671
Unread 24-04-2010, 17:38
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Yeah. I'd say go ahead and put some tensioners in the prototype, and if you find yourself not using them throughout testing, then leave them out if you use swerve for next season.
The other option is to leave 'em out now and see if you feel you need them. This is a good option if you feel really confident about the tensioner design. However, if it's something you think you might not get right the first time and you'd like to experiment with, give 'em a shot now. Then you can redesign for next season and fix any problems there were.
Keep up the great work!
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 24-04-2010, 17:42
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
What thrust bearings are you using in this design? Do you have a link? Thanks!!!
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 24-04-2010, 17:48
FRC #5817 (Uni-Rex)
Yeah they are from silverthin.com
They have a ton of bearings there I think I am using a 2 inch id and 2.5 inch od
team 1671
Unread 24-04-2010, 18:05
CraigHickman
Posts: n/a
Random thought regarding this design: I noticed you were using punched and folded sheet metal for your chassis. Have you thought at all about using the same for your module? The precision is doable, and should be cheaper than a pure milled construction. You also might be able to find a middle ground with some parts milled and some punched to cut down on cost.
For example, the top plate of the module milled, with punched sheet pieces for the "yokes" of the module.
Might be something to take a look at for cost reasons.
Unread 24-04-2010, 18:08
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
what do thrust bearings do anyway? I know I should know this, but I don't.
what specific purpose do they serve in mounting a coaxial swerve module?
pic: 1671 swerve module 2.0 steelerborn Extra Discussion 10 22-04-2010 18:41
pic: 1671 Swerve Module steelerborn Extra Discussion 14 20-04-2010 08:49
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
