Go to Post We need to find the female engineering mentors in FIRST and start having them present/co-present technical conferences at the championships. We need to start showing the girls on the teams that there are female engineering "rock stars" to look up to. - Kims Robot [more]
Unread 23-04-2010, 17:13
mikelowry mikelowry is offline
FRC #1771 (N.G.R.)
mikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to all
1771 Prototype "Drift" Drive
I was inspired by 148's and 217's drivetrain this year, and decided I wanted to try out a similar one. I finished the module, some renders can be found here. Any feedback or suggestions would be great!
So how it works: The main center hole is for the drive shaft to go through. This shaft also serves as the pivot for the whole module. The brackets on top are the mounts for the cylinders that will rotate the module. The skid on the bottom is to prevent both wheels from touching the ground at one time. The traction wheel is geared slow and strong (I haven't figured out the exact speeds I want yet), while the mecanum is geared really fast.
2008 Xerox Creativity Award - Championships
2009 Rockwell Automation Innovation in Control award - Peachtree
2009 GM Industrial Design Award - Palmetto
2009 Palmetto Champions <1771 2415 21>
Unread 23-04-2010, 17:35
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Re: 1771 Prototype "Drift" Drive
This is a great way to implement the 148/217 drive train without having to use a wheel in the center and a motor for it. I hope you guys end up doing this because it is a fantastic idea and I am very interested to see how it works out.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 23-04-2010, 17:37
Jared Russell's Avatar
Taking a year (mostly) off
I've been tossing this one around in my head for a while now. Literally, same idea (fast mecanum, strong traction wheel).
There are pro's and con's to putting the traction wheel on the inside vs. outside (being able to turn at all on the traction wheels vs. being unturnable - there are times you could want either).
Let us know how it works out!
Unread 23-04-2010, 17:41
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
461 prototyped a similar system (same concept) in the fall. It worked realy well. I will send the IT guys an email and see if we can't get some pictures or videos posted, though I think we were putting together a white paper.
Unread 23-04-2010, 17:45
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
This is awesome! This has been on Exploding Bacon's things to consider for offseason projects since the middle of build season
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 23-04-2010, 18:11
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
I've been thinking about this for a little while too, I would do it a bit differently, direct driving one of the wheels and pivoting off that. I'm probably going to throw together a CAD of it when my exams are over.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
How do you plan on hooking these pods to the robot? Also are you thinking about placing a cim per pod or 2 cims and a gear box somewhere else?
Sounds like a good idea but I can think of one potential problem if you were to use this design in a game. If you are pivoting around one wheel that would mean the other wheel would need to be lowered below that wheel thus raising the entire robot. Now depending on how much that raises the robot I can see a situation where the bumpers are no longer in a legal zone. Right?
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 23-04-2010, 18:14
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Originally Posted by corpralchee View Post
How do you plan on hooking these pods to the robot? Also are you thinking about placeing a cim per pod or 2 cims and a gear box somewhere else?
It has to be 1 CIM per pod, you can't power 2 pods together with a mecanum wheel in the pod.
Unread 23-04-2010, 18:36
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Must be a popular idea; I've also had a design in the works (albeit not something build-able with my kind of resources... more of a Chicken/Wrangler fantasyland robot)
I think it's a killer concept:
- "fast" mode with omnidirectional capability is ideal for offense
- "defense" mode gives you four geared down traction wheels in the corners: great for defending and avoiding being pushed while scoring from a stationary point (like you needed to do in 06/07).
- Uses only four motors!
I love how you get nearly all of the advantages of a drivetrain with swerve modules, but you don't suck up so many motors (only four!). Construction could be simpler as well, if some thought is put into design work.
The one major drawback between this design and the one that 148/217 use is the lack of full power being directed to the floor if you get kicked up on just two wheels (like whenever you would be pushing, for instance). However, this can be resolved by engaging/disengaging the two drive motors on one side. This is what I was aiming for in my model, but it wasn't implemented very well.
PS: If anyone wants a copy of my CAD files, shoot me a PM.
Unread 23-04-2010, 18:51
AdamHeard's Avatar
Lead Mentor
I drew up something similar in 06, modules had traction wheel inner, mecanum outer. Direct drove the tracion wheel which was linked via chain to the mecanum geared up (in hindsight, it'd make more sense to invert the gearing there). Pivoted around the traction wheel shaft.
I'd be stoked if someone built it, I'd love to see it in action.
Unread 23-04-2010, 19:06
FRC #1771 (N.G.R.)
I think I can get our laser cutting sponsor to cut everything out for it, so hopefully this can be driving in a little bit!
Thanks for all the kind words.
The traction wheels are going to be toward the inside of the robot so that they wont scrub steer. Oh and I forgot to mention that the frame will be done out of 1771's signature tabbed lasercut baltic birch plywood.
Unread 23-04-2010, 19:07
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
I drew up something similar in 06...
Yeah, reminded me of something I worked on in another life, too...
SpamThingAcon
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
Unread 24-04-2010, 15:35
user0's Avatar
user0 user0 is offline
Registered User0
AKA: Hiroshi
FRC #0461 (Boiler Invasion)
Team Role: Student
user0 is an unknown quantity at this point
Send a message via AIM to user0
Team 461 built this type of drive during out preseason. But, once the game was released we thought it kind of nullified because we didn't think it would make it over the bumps.
But here are some pictures. The drive works magnificently ^_^. We call it Jump drive, because when you switch, it hops a little.
http://boilerinvasion.org/index.php?...2_itemId=24653
Unread 25-04-2010, 00:15
user0's Avatar
Registered User0
AKA: Hiroshi
Team Role: Student
team 461 created a similar drive ( we call it jump drive) in the preseason. The drive worked marvelously.
Here are some pictures.
"Prototype This" on Discovery Channel Dick Linn General Forum 15 25-10-2008 23:24
"call of function without prototype" railerobotics Programming 7 21-01-2006 19:59
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
