Go to Post If there is anything I have learned from ChiefDelphi, it's to never underestimate the coding genius that is Brandon Martus. - Amanda Morrison [more]
Unread 24-04-2010, 12:35
DWirth DWirth is offline
FRC #2509
DWirth is an unknown quantity at this point
Joystick Button Controlling Relay
Hello,
I'm having problems with the code I have written. Every time I compile the .cpp file it tells me:
'If' undeclared (first use of the function)
'Else' undeclared (first use of the function)
I think this means that the if and else statement do not know what they are controlling. Please correct me if I'm wrong. This is my code below:
				If(stick->GetRawButton(1));
					relay1->Set(Relay::kForward); // run line when button is pressed
				Else;
					relay1->Set(Relay::kOff); // or run this line when button isn't pressed
Unread 24-04-2010, 12:52
Re: Joystick Button Controlling Relay
if and else should all be lowercase, they are reserved words.
You also shouldn't have a semicolon after the if or the else http://www.cprogramming.com/tutorial/lesson2_tg.html
Unread 24-04-2010, 13:03
FRC #2509
Perfect, thanks for the advice and resources. Seemed to have solved the issue.
Controlling the camera with a joystick Dakabt Programming 9 01-02-2010 21:51
Joystick Button Issues pyr0b0y NI LabVIEW 6 21-04-2009 09:29
joystick button furiousgeorge Programming 5 07-02-2009 15:57
How do I program a relay to turn on and off by pressing a button on the joystick? eweathers NI LabVIEW 4 28-01-2009 22:34
Speed controlling a relay..?!?!?one/???? Monochron Programming 13 17-02-2007 21:43
