Re: Help with CNC machining STL file - MasterCAM X
I'm not an engineer, but I'm going to assume that you're using a mill to do this. Wouldn't it be possible simply to machine down around the shape manually? After all, the shape's been cut out already.
| MasterCam, Solidworks & CNC Help | R.C. | CAD | 9 | 09-11-2008 23:03 |
| Machining plastics with CNC | Ben Mitchell | Technical Discussion | 14 | 13-03-2007 14:01 |
| Help! making an inventor file into an autodesk file | kjhobin | Inventor | 5 | 19-03-2006 23:04 |
| help with 06 denso motor cad file | Jim Schaddelee | SolidWorks | 3 | 29-01-2006 22:37 |
| just wondering [g code cnc machining] | [527]phil | Technical Discussion | 16 | 17-10-2004 17:21 |
