Go to Post I don't care if you use hot dogs for wheels. If you're scoring points, and you fit the strategy, it's fine. - evanperryg [more]
Unread 24-04-2010, 16:28
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Electrical Board Mounting
I was wondering how other teams mount their electrical board. Do you mount all you electronics on one board or do you space the electronics out? What Material do you mount you electronics on (aluminum? Polycarbinate? Other?)? What do you use to fasten you electronics down (Screws? Zip Ties?[how do you mount the cRIO with zip ties?])? How do you keep you wires organized? Any pictures would be appreciated.
Unread 24-04-2010, 16:34
kjolana1124's Avatar
kjolana1124 kjolana1124 is offline
AKA: Kelsey Jo Starr
FRC #1124 (The ÜberBots)
kjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant future
Re: Electrical Board Mounting
I'll try and find 2010 if I can, but here's our 2009 electrical board
We mount everything with screws. We also try and put this on last if possible so we can figure out where to put everything so that the least amount of wiring is required. As far as organized...well that's a work in progress. Basically we just try to make it so we know where it is fast. It doesn't have to look all that pretty. Zip ties are used for wires we (hopefully) don't have to move around a lot.
Woodie Flowers asked for Super Nerds
We're giving him ÜberNerds
~Tweeeeter~
2010 Northeast Utilities Hartford Regional Champions
2010 WPI Regional Chairman's Award Winners
2008 Archimedes Division Champions
2008 Hartford Regional Champions
Unread 24-04-2010, 16:38
kgzak's Avatar
AKA: Kris
is that aluminum that it is mounted to? If so how is the cRIO isolated?
Unread 24-04-2010, 16:41
No it's plastic. We actually took the excess material from our spiral for it. That's attached the aluminium frame of the robot.
~Tweeeeter~
Unread 24-04-2010, 16:46
rcmolloy's Avatar
rcmolloy rcmolloy is offline
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Just like Kelsey stated, we also mount everything with hardware. Also, we use zipties to keep everything nice and neat. As you can see with the Jaguars, its pretty much a mirror image on the other side with the cRIO. (There were two different heights on both sides but that doesnt matter ) If you have any more questions about how we mounted everything, I can ask around but I think you may have all your answers already.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 24-04-2010, 17:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We've built a plywood box the past two years, and screwed most of the parts to it, we bolted the cRio since it's pretty heavy. Last year was a big flat box sitting upright, cRio was attached inside the bottom edge. This year it was also a box, laying flat, most parts on the top of it, cRio inside, also had room for the battery.
ID:	9049  Click image for larger version
Unread 24-04-2010, 17:27
seannoseworthy's Avatar
seannoseworthy seannoseworthy is offline
FRC #2200 (MMRambotics)
seannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to behold
Send a message via MSN to seannoseworthy
Typically we mount all out electronics on a sheet of plastic, this year everything was very close together but easily removable if anything should go wrong. We super glue our wires together for a look once we know where everything is mounted.
Unread 24-04-2010, 19:17
TEE's Avatar
TEE TEE is offline
FRC #0201
TEE has a spectacular aura aboutTEE has a spectacular aura aboutTEE has a spectacular aura about
In past years, we've mounted everything on an electric board, but this year, in order to be able to fit under the tunnel, go under the bump, and hang, we mounted electrical components in several places.
Our cRIO was between the back wheels (we can honestly say we've scored with the cRIO ), the jaguars (which we later changed to viktors) were mounted close to the motors, and the relay board and the battery were mounted close to the cRIO. I'll see if I can find a picture...
Unread 24-04-2010, 19:21
TEE's Avatar
TEE TEE is offline
FRC #0201
http://www.flickr.com/photos/team201...7623302836459/
This is the best picture I could find... you can see a vacuum-like hose around the side of the robot, and that's where we routed most of the wires.
Unread 02-05-2010, 13:04
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
I just joined the team this year, but last year, there was a large vertical plywood board on the back of the robot that had just about all the electronics mounted to it. A lexan guard could be slid in to protect them.
Just under that board, there's an aluminum plate resting on the chassis (so when you look at the robot from the side, you see sort of an L shape) that extends into the robot. Our cRIO is mounted on one side of that board, and a hole was cut into the plywood so that we could place a battery on the aluminum plate.
This year, some of the electronics were scattered. We have a 4-CIM drivetrain in the rear of our robot, and there's a lexan cover over them. The PDB and sidecar went on that lexan cover (it's braced by aluminum L, so it's fairly sturdy), mounted down with screws. Behind the CIMs - between our rear wheels - on the chassis, there's a lexan plate occupied by 4 Victors to control those CIMs. The other Victors - the 3 controlling the kicker, acquirer, and hanger - are mounted around the frame, wherever convenient. The drivetrain Victors are mounted with screws; the others with (industrial strength) Velcro. The reason is that the drivetrain Victors had a space allotted for them, whereas very little planning went into the placement for the others. Our cRIO is mounted on plywood, in front of our drivetrain CIMs, using screws.
Because all of the electronics are mounted on stuff that's very liable to transmit shock (physical shock, that is), we have shock mounts for all the electronics mounted with screws. For those shock mounts, we cut up a yoga mat (so if your parents ever tried and stopped doing yoga, you know what you can do with that yoga mat now!). For those electronics mounted with Velcro, no shock mount was necessary because the Velcro serves as a shock mount in itself.
Unread 02-05-2010, 13:18
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
Our Electronics Panel was one double sided piece of lexan which rested on 2 pieces of aluminum on our robot, here are some pictures.
Always use bolts to mount (except the gaming adapter, zip ties for that), and zip ties to organize.
http://www.vandenrobotics.com/plogge...icture&id=2837
http://www.vandenrobotics.com/plogge...icture&id=2814
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 02-05-2010, 13:24
Chris is me's Avatar
AKA: Pinecone
I'm basically only posting this so that future Shaker Robotics kids will see it and tell themselves "never again"...
We had about 5 preship electrical boards. We cut two of them wrong. We had a third wired up neatly, then we changed the structure of the robot a few hours before ship so we had to redo it all in a few hours at WPI. We kind of just mounted the Victors wherever they fit. Since we're probably removing the entire pneumatics system, the new electrical kids will have a chance to rewire the whole robot with all of the scattered electrical parts closer together. Everything should be mounted on 1/8" lexan, or the trimmed piece of pultruded fiberglass up top.
Unread 02-05-2010, 13:31
kgzak's Avatar
AKA: Kris
I was never going to use zip ties but people on my team said other people use them.
Our board last year was an "L" shape on the side of the robot. It was all aluminum but the cRIO was on a piece of polycarbonate bolted on with plastic screws. Everything else was put on aluminum boards with bolts and the holes where tapped to save on weight.
This year we started off with a flat piece of aluminum with all the electronics mounted on there. The cRIO was sitting on a piece of polycarbonate but somehow metal screws were used to fasten it to the board. So after that one of our mentors got scared about grounding and had us switch to a full poly carbonate board in an "L" shape. We used plastic screws to fasten everything to the polycarbonate.
Unread 02-05-2010, 13:34
NickE's Avatar
NickE NickE is offline
_
We always try to place all of our electronics on the robot's baseplate. This year and last year, they were on a waterjetted aluminum plate with pre-drilled mounting holes for everything. All of the holes are then tapped and we screw the components into them. The cRio was isolated with a rubber pad, although the powdercoat is not conductive.
Wires are run so that they can be easily traced by looking at them. Zip ties are used when necessary.
Here's this year's board without the cRio. Some of it needs to be tidied up, but its mostly done except for the wires in the bottom left corner.
-Nick
Unread 02-05-2010, 13:47
MrForbes's Avatar
AKA: Jim
Ask Tom about Megamaid
2898 electrical board FlyingHedgeHog Electrical 13 03-02-2010 14:59
Mounting on the Control Board seanl General Forum 3 06-03-2009 20:46
Mounting the IR board Aratznes_Scythe Electrical 4 18-02-2008 02:07
Pneumatics Board/Mounting Components ASmith1675 Pneumatics 2 06-02-2008 13:47
Mounting Electrical Parts SpaceOsc Rules/Strategy 21 15-10-2004 22:52
