Go to Post Magic Smoke. One whiff and you never forget. - JohnBoucher [more]
Unread 24-04-2010, 18:12
CraigHickman
Posts: n/a
Re: pic: 1671 swerve module 3.0
Originally Posted by PAR_WIG1350 View Post
what do thrust bearings do anyway? I know I should know this, but I don't.
what specific purpose do they serve in mounting a coaxial swerve module?
A thrust bearing is a bearing that is designed to support both radial load and axial load. Some are designed for more of one than the other. A Thrust bearing: http://en.wikipedia.org/wiki/File:Se..._din728_ex.png
Unread 24-04-2010, 18:36
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Here is the link to the bearings we are using.
http://www.silverthin.com/11jsa.htm?part=JSA020
The part number is JSA020.
Thrust bearings are used against an axial force, meaning that the force is coming parallel to the shaft. So for instance with a swerve module the most likely force is going to come from a side hit, which is parallel to the shaft. Thrust bearings increase the strength of the module with the frame so that you can keep driving.
Good enough is the enemy of anything great!
team 1671
Unread 24-04-2010, 18:53
AdamHeard's Avatar
Lead Mentor
1717 makes coaxial modules out of sheet, look at their design.
Unread 24-04-2010, 21:49
Also look at their use and implementation of belting. The belt paths are pretty slick!
http://picasaweb.google.com/RoboticW...94820442400434
pic: 1671 swerve module 2.0 steelerborn Extra Discussion 10 22-04-2010 18:41
pic: 1671 Swerve Module steelerborn Extra Discussion 14 20-04-2010 08:49
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
