Go to Post but yea. people have this perception of robots as like, the terminator. you don't have to be a super genius to do this stuff. - christina_omg [more]
Unread 25-04-2010, 13:50
maverickfan138's Avatar
maverickfan138 maverickfan138 is offline
Still hooked on FRC
AKA: Marc Antinossi
FRC #0573 (Mech Warriors)
maverickfan138 will become famous soon enoughmaverickfan138 will become famous soon enough
Drivetrain experimenting
This summer, a few of my team mates and I are looking at experimenting with certain drivetrains to learn the pros and cons of each combination we can test. Basically, we want to find out which drivetrains have a lot of torque, which ones have a lot of speed, and which ones have a combination of each. So far, we are going to be looking into the following:
CIM motor/Toughbox transmission
CIM motor/Dewalt transmission
Dewalt Motor/ Dewalt transmission
We will also be looking at different types of wheels to see if they have any effect on the torque(for example, if they slip or not).
If anybody else has any other suggestions for motor/transmission combos for us to test, please share. We will probably post our research on here, so if anybody would like a request for a certain drive train, please let us know. Any help we can get is appreciated.
Unread 25-04-2010, 13:55
hayonet's Avatar
hayonet hayonet is offline
Mechanical/CEO
AKA: Hayon
FRC #1676 (Pascack Pi-Oneers)
hayonet is on a distinguished road
Re: Drivetrain experimenting
I don't know how it works, but I've seen some teams implement planetary gearboxes that allow the use of Fisher Price motors in place of a CIM in a toughbox or dewalt transmission. I've heard of combining a Fisher price motor and a CIM in a singe gearbox.
I'm interested in seeing how that works.
Unread 25-04-2010, 21:15
Can you describe the test setup you are considering using, and the test equipment? Do you have a dynamometer so you can measure torque vs speed, or are you planning on just measuring stall torque and no-load speed?
Will you also be measuring motor current and voltage at each test point?
Unread 25-04-2010, 21:18
Banebots sells planetary gearboxes with very high stepdown gear ratios. FP motors can be adapted to fit these gearboxes by replacing the pinion gear. For more info, do a search on CD for the keywords "pinion" and "banebots".
Unread 25-04-2010, 21:35
AndyMark also sells planetary gearboxes that allow FPs to interface with gearboxes that also have CIMs.
Unread 25-04-2010, 21:55
Still hooked on FRC
AKA: Marc Antinossi
To be honest, we were just planning on switching transmissions and motors on past robots and pushing heavy stuff/other robots around. It would be very unscientific, watered down experimenting.
We are planning on looking into planetary gearboxes as well, like the Crazy Chicken Transmission. I'll be sure to let my friends know about Banebots and look into their products.
Unread 25-04-2010, 22:04
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Well, speed and torque depend entirely on the gear ratios and motors you use. Testing a few drivetrain configurations is an excellent idea, but make sure you don't neglect the physics behind what you're doing.
In my opinion, the most important characteristics of a drivebase are its maneuverability, robustness, and ease of construction. Speed and torque are easy to trade off by simply using different gears or sprockets.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 25-04-2010, 22:18
You mentioned these three combinations:
1) CIM motor/Toughbox transmission
2) CIM motor/Dewalt transmission
3) Dewalt Motor/ Dewalt transmission
For the first one, the torque vs speed motor curve for the CIM motor is available at the andymark.biz website. And the gear ratio for the toughbox is specified there too. So with just a tiny bit of physics and math, you have a good estimate (neglecting friction) of what the torque vs speed curve at the wheels would be.
For the second one, just look up the gear ratio for the Dewalt transmission and compare it the the toughbox spec. This will tell you if you will get more torque and less speed, or less torque and more speed, compared to #1.
For the third one, look up the motor specs for the Dewalt motor and compare it to the CIM. This will tell you how #3 stacks up against #2.
Unread 25-04-2010, 23:15
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Dewalt motors are not legal motors since they did not come in the kit of parts. Unless you have a non FIRST application, I do not see why you would want to test them.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 25-04-2010, 23:49
NickE's Avatar
NickE NickE is offline
_
Maybe they're planning ahead in case they're in the 2011 KoP.
Unread 25-04-2010, 23:54
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
You could save some time and money and do some calculations before hand to give you an overall idea of what gear ratios you want with a given motor and wheel dia.
Give this a shot,
http://www.chiefdelphi.com/media/papers/2059
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 26-04-2010, 00:15
Chris is me's Avatar
AKA: Pinecone
Give this a shot,
I was just going to say... this is all stuff you can figure out mathematically..
Unread 26-04-2010, 02:12
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Well we are going to test some dewalt gearboxes this summer too. There other things to test besides drivetrain performance. We don't really need to test performance since we can calculate it before hand. I doubt the theoretic calculations will be drastically different from real world results.
The real test for us is if we can convert the gearboxes to adapt a CIM or a FP in a reasonable time using tools in our wood shop. We really don't want to find assembly and modification issues in the middle of the build season. We will work out the kinks now to save us time later.
We may also tryout fancier stuff such as automatic shifting or something like that.
Also, we want to try using the dewalt motor and gearbox (actually the whole drill) to make instant prototypes. In the past, we used a spare drill grabbing a shaft with its chuck. We want to try a more integrated system where we can bolt the drill to the prototype device, change the gear reductions easily by shifting gears and using different combinations of sprockets and finally, be able to use the drill's trigger switch for early tests and later be able to switch to a speed controller. Hopefully, we can use this to make better prototypes.
Unread 26-04-2010, 08:59
Lowfategg's Avatar
AKA: Tyler Moser
This might be of some help if you have not seen it already,
http://www.chiefdelphi.com/media/papers/1592
Unread 26-04-2010, 17:48
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
As an additional note, if you choose to do the math remember to include basic efficiency losses. 1% per spur-style gear is usually adequate. Which means that a planetary tranny is going to be far less efficient than one with only 2 or 3 gear interactions like a toughbox.
I suggest, before you do any testing, you start reading a bit about different styles of transmissions and their strengths and weaknesses.
drivetrain!!! hiimcristhian General Forum 3 12-01-2008 23:51
Swerve Drivetrain Pelicano234 Technical Discussion 18 13-05-2007 12:55
pic: Experimenting with a robotic arm Guy_E Extra Discussion 4 14-01-2007 09:12
drivetrain systems BlacKnight6604 General Forum 1 08-01-2004 10:30
Drivetrain Hawk135 Technical Discussion 3 06-01-2003 22:14
