Go to Post Wins = Attention Attention = Sponsors Sponsors = Money Money= being able to do more. a vicious cycle...but it is what it is - Protronie [more]
Unread 26-04-2010, 03:22
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Re: Unexpected results from Encoder::GetRate()
Originally Posted by vamfun View Post
This type of comment doesn't help.. please refer to a flawed statement in my logic as you did above. I have corrected the table...and I see no reason to adopt joes algorithm since it is a less accurate predictor in position when an event occurs. At the time an event occurs, the best you can do is have zero error at that time... which is what my algorithm does. Anything better than this must rely on some future assumed behavior, e.g. moving to an angle where joe's error is zero and staying there. If all angles are equally likely, then mine would be the optimal estimator at the time the estimate is updated.
Ok, allow me Alan. The flaw in the logic is what happens between events. I finally put my controls hat on instead of my optimal estimation hat. The added one unit of hysteresis with my algorithm does cause major headaches when trying to do closed loop feedback control of position. This is what was bothering Alan and Joe. If I had to control position, I would certainly choose Joe's algorithm since one can control to a sharp edge without phase lag. Although it is accurate, my algorithm creates a control dead zone with a width of + or -1 precision unit centered on the last event. That is a big price to pay for the improved rate noise from an oscillating edge.
So Joe has reached a compromise position by providing a GetDistance() that is control friendly but sensitive to oscillating edges and a GetRate() that is insensitive to oscillating edges.
I still need to study Kevin's solution since it appears to have the hysteresis in it.... yet Alan found it acceptable for his control problem. Perhaps Alan can describe what type of control they were doing at that time.
[BB] An unexpected change in plans yodameister General Forum 22 01-12-2009 21:26
Inconsistent reading from encoder get rate rwood359 National Instruments LabVIEW and Data Acquisition 5 13-01-2009 19:10
Results from Drexel, thanks from 365. archiver 2001 1 24-06-2002 02:44
Results from GLR? archiver 2001 0 24-06-2002 02:44
results from regionals archiver 2000 0 23-06-2002 22:31
