Go to Post Can you restate your observation in a manner that reconciles with physics? - Madison [more]
Unread 26-04-2010, 13:31
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Re: Pan/Tilt Assembly
Our team also used McMaster Part #: 18635A52 for our turreted shooter last year. This bearing worked very well... it was *very* smooth and seemed like it could support far heavier loads than our 20 pound, centrally-mounted shooter!
To control it, we simply used a single rivet to attach a timing belt, and ran the timing belt with a globe motor - we had a push-button limit switch at each extent of the turret's travel, and an encoder on the output shaft of the globe motor. I can't recall the specs on the encoder, and I'm only 80% sure that the encoder was mounted on the output shaft.
Altogether, this set up worked very well for us - it allowed us to autonomously score a couple moon rocks, too!
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 26-04-2010, 14:09
kwotremb's Avatar
kwotremb kwotremb is offline
FRC #3414
kwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to behold
Our team did the same thing as the others last year for our rotateable turret. The turn-table comes with a screw on the side of the turntable, we just cut slits in a timing belt and used that screw to attach the timing belt. Then a globe to rotate with a small gear on it to turn the timing belt.
2013: Team 3414 Hackbots
Waterford District: Finalist (51, 3604)
Livonia District: Winner (3641, 240), Spirit Award
MSC: 6th Seed Captain (862, 3641), Spirit Award
Worlds: Seeded 32 in Curie
Past Years:
Team 3414: Hackbots, 2013-Current, Mentor
Team 818: Steel Armadillos, 2008-2012, Mentor
Team 93: N.E.W Apple Corps, 2002-2003, Student
Unread 26-04-2010, 14:17
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
In 2009 we built a turret for our robot. It was made from a PVC ring and four V-Channel bearings. It worked flawlessly and still works perfectly today. We will also be modifying it to be our T-Shirt cannon robot. Here are some pictures to help out.
The ring of screws created a sprocket out of the PVC ring so the gates belt could rotate it.
Look closely at the top of this one and you can just see the final product. In this picture the turret is pointed to the right and the motor is visible behind the "C" in "Force".
I'll see if I can get some more detailed picture of the drive mechanism. BTW, we included a pot for position feedback. That allowed us to actually follow another robot and fill 'em up in Autonomous.
Unread 26-04-2010, 14:28
pfreivald's Avatar
AKA: Patrick Freivald
We used a lazy susan for our 2009 shooter as well -- we rounded a very large ring out of a piece of plywood and then Gorilla glued a timing belt to the outside to turn it into a giant sprocket, then drove it with a timing belt sprocket attached to a globe motor.
It worked *great*, with about 340 degrees of movement before we ran into the edges of the belt -- but that's where we had our limit switches anyway!
An encoder was mounted to the assembly, but we didn't end up using it.
Name:	Robotics Pictures 125_Smaller.JPG
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 26-04-2010, 14:47
Zflash's Avatar
Zflash Zflash is offline
AKA: Erich Zende
FRC #1319 (Flash)
Zflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud of
1319 did this in 2006 with our pan and tilt turret used for shooting poof balls. The only difference was we used an aluminum ring instead of a PVC one as well as 8 (2 on each corner) V-channel bearings. It certainly does work flawlessly. If you have a copy of the behind the design book our robot is featured in it and I believe has a close up shot. PM me if you want more info or pics.
Peachtree '08 Champion Thanks 343 & 547
Galileo '07 Champion Thanks 173 & 1902
Palmetto '07 Champion Thanks 832 & 342
Boilermaker '06 Champion Thanks 1272 & 85
Unread 26-04-2010, 15:23
The TechnoKats t-shirt cannon was mounted on the team's Rack & Roll practice drivebase for a while. Tilt control was a simple chain and sprocket on the arm's "shoulder" joint. There was no need for a pan mechanism, as the robot itself can turn to face whatever direction is desired.
If we hadn't donated the 2008 Overdrive robot drivebase to our sponsor for target practice, it would have made a fantastic t-shirt cannon platform. Maybe we can mount the remaining superstructure to a simple mecanum drivebase and drive it around that way.
Unread 26-04-2010, 15:29
Joining the 900 Meme Team
FRC #0079
http://www.chiefdelphi.com/media/photos/22693 shows a cad rendering of the 2006 shooter we did on RUSH. Not pictured is the spur gear we had powering it. That can be seen http://www.chiefdelphi.com/media/photos/22666 Here is the whole thing http://www.chiefdelphi.com/media/photos/23193.
We were fortunate to have the water jetting done for us. If you have more questions I will see if I can get someone to either get me some more pictures of it or let me back into the shop so I can snap some of it for you.
Unread 26-04-2010, 15:39
CoachPoore CoachPoore is offline
AKA: Noel Poore
FRC #1519 (Mechanical Mayhem)
CoachPoore has a spectacular aura aboutCoachPoore has a spectacular aura about
Send a message via AIM to CoachPoore
The sensor was indeed mounted on the output shaft of the motor and it was a US Robotics magnetic position sensor. The bearing worked great for us - it even has pre-tapped mounting holes in it.
2011 Granite State Regional Winners with teams 175 and 176
2010 Granite State Regional Winners with teams 1073 and 1058
2010 Granite State Regional Innovation In Controls Award Winners
2010 North Carolina Regional Engineering Excellence Award Winners
2010 North Carolina Regional Finalists with teams 1772 and 1741
Camera pan/tilt kit WGRAY Kit & Additional Hardware 29 22-01-2010 12:01
tilt/pan away Tangello_angela Programming 4 24-01-2007 16:20
Question about pan/tilt itsme Programming 1 12-01-2007 10:49
pan & tilt errors itzrobz Programming 2 19-02-2006 19:12
White Paper Discuss: Assembly of the 2006 pan/tilt camera mount Justin Stiltner Extra Discussion 2 09-01-2006 11:17
