Go to Post No email, no telephone, no FIRST. I can't wait.... - RoboMom [more]
Unread 26-04-2010, 14:14
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Unexpected results from Encoder::GetRate()
Originally Posted by vamfun View Post
Your scheme and mine will both have 1 count ambiguity...it just occurs at different times. I am interested in the best estimate of angle not just the count.
Error = true - encoder
So if we are oscillating in a band about the 1 deg edge [.9 to 1.1], my algorithm will give a better estimate of angle position on reversal and we are the same going forward past 1.
Aside from the fact that your algorithm has a different value at the same position depending on the direction of approach, I must also point out that the mapping of "true to encoder" is arbitrary and is chosen to optimize for accuracy. What I mean by this is you have chosen that the code "1" represents true [1 .. 2) where as I would argue that the code "1" represents true [0.5 .. 1.5). Hence my algorithm is more accurate than yours given that definition.
We have two events.... crossing same edge in forward and reverse directions.
Again, I contend that the definition of speed is distance per time. Distance is the difference between two positions. If the encoder reverses directions, then the only thing I know about the distance is that it is somewhere between (0 .. 2) counts of the encoder. I effectively have no (known) distance. How, then, can I claim to compute a speed with no distance?
Therefore, I say again that I do not have two events... I have one. As such, I do not report an invalid rate. It is not a patch to the algorithm, it is fundamentally accurate and required.
-Joe
[BB] An unexpected change in plans yodameister General Forum 22 01-12-2009 21:26
Inconsistent reading from encoder get rate rwood359 National Instruments LabVIEW and Data Acquisition 5 13-01-2009 19:10
Results from Drexel, thanks from 365. archiver 2001 1 24-06-2002 02:44
Results from GLR? archiver 2001 0 24-06-2002 02:44
results from regionals archiver 2000 0 23-06-2002 22:31
