Go to Post We built an ineffective machine, all by ourselves! Yay for us! - Alan Anderson [more]
Unread 26-04-2010, 13:20
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Swerve Module Mounting Bearing
I am pursuing designing a new coaxial swerve/crab/swivel drive train for my team. If possible, could those who have designed and used similar swerve modules please leave your feedback? I know Craig Hickman has designed several coaxial swerve modules, which seem to use similar mounting types. Also, I know the 118 swerve modules use similar bearings, so I'd particularly appreciate hearing from these two groups; however, many others have similar designs/insights!
Two pictures are attached in the zip folder. Fyi, the two semi-transparent plates are made of 3/16" thick aluminum, but I temporarily made them semi-transparent for the sake of the picture.
All elements are made of aluminum, except for the two pale blue/gray rings, which are Silverthin Bearings (part no. SAA15XLO, http://www.silverthin.com/4saa.htm). The tall central hub would be bolted onto the roof of the pod. The two semi-transparent plates would be bolted around two aluminum box rails. The two bearings would be pressed into these plates. The ring with the holes in its perimeter at the top of the hub would be screwed onto the hub, and removed during installation.
To install, the two bearings would be pressed onto their respective plates, the bottom plate would be slid down the hub from above, bearing-side down; the upper plate would be slid down the hub from above, bearing-side up. After these have been slid on, the upper ring would slide down from above, and be fastened with 4 #10 bolts that are tapped into the hub.
The idea is that the upper plate/bearing takes the majority of the weight of the robot under normal functioning, the lower plate/bearing prevents the pod from sliding out from under the robot when it's lifted, and they together share the radial and moment loads. Obviously, that's a simplified explanation of the loads...
I have never been quite clear on how other teams support pods that are only supported from above... Is this similar to others' designs? Would this be able to handle the radial, thrust, and moment loads? To me, this seems functional; however, I have little experience with swerve modules. Thank you!
Nathan
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 26-04-2010, 20:11
Re: Swerve Module Mounting Bearing
I've always liked Wildstang's mounting system for their modules. So, when we made a swerve last summer, that's the type we used, more or less. I'll see if I can describe what we did.
Up top, we had a thrust bearing for the weight of the robot, and a bushing for horizontal loads. To take the module out, all we had to do was remove the monster snap ring that held it all together. And then, at the bottom of the module, we had a round sheet metal ring with delrin rubbing on it. The ring was mounted to the robot frame, and the delrin was mounted to the module. By holding the module laterally in two spots, we didn't have to worry about moments up top in the bushing, which made things a lot easier. We were originally going to just use a bushing to hold the weight of the robot, but we found a $6 thrust bearing on McMaster that fit our needs, and it was hard to say no after that.
If you find a picture of Wildstang's module on CD-Media, you'll see them holding the module in two spots like we did.
EDIT: or you can look at the picture that Akash Rastogi posted...
Good luck!
Unread 26-04-2010, 20:17
AdamHeard's Avatar
Lead Mentor
Our coaxial module was entirely supported on top by a big 1" bronze bushing about 1.25" long, and it sat on two thrust bearings that were just 1/16" thick bronze disks.
Not as efficient as bearings, but sure as heck a lot cheaper.
Unread 26-04-2010, 20:19
Here's a picture of what Austin's referring to. Its definitely the cleanest mount I've seen.
Adam, are these the same bushings you used on the King Krab?
Unread 26-04-2010, 20:23
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Bushings are more than sufficient for the application.
Though frc118 did deploy silverthin bearings successfully for many seasons they would be the first to tell you that these bearings are often the weak point in their setup.
Fee free to review our co-axial swerve design or our Wildstang clone. www.team221.com
Good luck!
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
AdamHeard's Avatar
Lead Mentor
Maybe, maybe not.
We just used bronze bushings for a 1" shaft, all sorts of options on mcmaster. Paid about $7 each iirc.
Unread 26-04-2010, 22:12
Aren_Hill's Avatar
Build Nifty Things
This year 1625 had a 1" long 1.125" ID roller bearing supporting the top of the module, 14$ a pop, got replaced with another bearing due to hard anodize wear but thats a material issue not a bearing issue.
A guy who likes robots.
Unread 26-04-2010, 22:46
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is online now
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Team 1983 used two oilite flange bushings from Mcmaster in addition to one needle roller bearing. A shaft collar was used to constrain the module vertically. The steering sprocket was bolted to this shaft collar to rotate the module.
A cross section of the module can been seen here.
Unread 26-04-2010, 23:35
jspatz1's Avatar
Happy Birthday! jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
This is quite similar to the 1986 module mount. Two inexpensive flanged bronze bushings supporting the pivot stem, captured with a collar. A roller thrust bearing took the load above the steering sprocket. The stem weldment was steel and quite stong, no lower support required. This mount was very simple and robust. We could change out a module in a few minutes. Here's some pics.
ID:	9058  Click image for larger version
ID:	9059  Click image for larger version
Unread 26-04-2010, 23:43
Just out of curiosity, were you considering doing an infinite rotation coaxial design, or were you planning on having the motor inside the module?
Unread 26-04-2010, 23:48
Brandon Holley's Avatar
I will post pictures of the swerve module I designed as part of my senior design project at Northeastern when I get them off my other hard drive...however here are my thoughts until then...
The silverthin bearings are a really nice solution, however they do have some issues, and they are ridiculously expensive (on order of ~$78 a piece)
I used the most simple/cost effective solution I could and figured I would start adding complexity and price as needed. My approach was to start from the ground up and see what was the simplest solution I could use.
I ended up taking a stock bronze bushing from mcmaster and bore-ing it out, and parting several smaller bushings from it. I pressed these into the plates that mounted the module to frame. Because I turned the bushings myself I was able to get a very precise fit on all of them. This resulted in a perfectly workable solution.
Had that not worked as expected, my plan of attack was to do a large sleeve like Adam described, and then use thrust bearings (w/ ball bearings) to alleviate the thrust load.
My swerve can be seen in action here: http://www.youtube.com/watch?v=mlla1xahkrk
pics to follow...
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 27-04-2010, 00:06
FIRST Fan(atic)
Thanks for the input, everyone! I've taken what you guys have been saying into account, and am finishing up an alteration of the what I'll call "bronze sleeve bearing with thrust bearing" design. I'll post some pics of that and the pod itself.
To answer your question, Dave, this module would be a true coaxial swerve module... the steering and drive for the module are located off the pod. I plan on having independent steering for each of the four modules, and shared drive for the right side with shared drive for the left side. This allows for any of the swerve drives capabilities... strafing (crabing), spinning in place, and pseudo-ackermann steering... although it sometimes requires rotating a pod more than 180 degrees to switch orientations.
Unread 27-04-2010, 00:26
Are you going to be supporting the Module at both the top and bottom like the classic 111 swerve, or only at the top like 118 used to do?
Unread 27-04-2010, 00:35
FIRST Fan(atic)
I plan on supporting the pod exclusively at the top - I have always been willing to take the extra design complications of the 118-esque swerve module to reduce the frame complications and to free up area at the base of the robot.
Unread 27-04-2010, 00:55
I also have a preference for the top supported modules. I'd advise trying to make the distance between the point of contact of the wheel and the lowest supported point on the outside axle as small as possible to minimize the moments that you will encounter.
pic: 1671 Swerve Module steelerborn Extra Discussion 14 20-04-2010 08:49
Swerve Drive and Ball Bearing Questions! Shelabot Technical Discussion 8 29-05-2009 12:33
Swerve Module Question adlai Technical Discussion 8 03-04-2007 21:20
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
