Go to Post Leaders are those whom inspire people; a good mentor inspires students. - Jeffy [more]
Unread 26-04-2010, 23:35
jspatz1's Avatar
Happy Birthday! jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: Swerve Module Mounting Bearing
Originally Posted by Dave McLaughlin View Post
Team 1983 used two oilite flange bushings from Mcmaster in addition to one needle roller bearing. A shaft collar was used to constrain the module vertically. The steering sprocket was bolted to this shaft collar to rotate the module.
A cross section of the module can been seen here.
This is quite similar to the 1986 module mount. Two inexpensive flanged bronze bushings supporting the pivot stem, captured with a collar. A roller thrust bearing took the load above the steering sprocket. The stem weldment was steel and quite stong, no lower support required. This mount was very simple and robust. We could change out a module in a few minutes. Here's some pics.
ID:	9058  Click image for larger version
ID:	9059  Click image for larger version
pic: 1671 Swerve Module steelerborn Extra Discussion 14 20-04-2010 08:49
Swerve Drive and Ball Bearing Questions! Shelabot Technical Discussion 8 29-05-2009 12:33
Swerve Module Question adlai Technical Discussion 8 03-04-2007 21:20
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
