Go to Post Breath in. Breath out. We still love you - its ok! :^) - KenWittlief [more]
  #44   Spotlight this post!
Unread 27-04-2010, 04:18
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: Anyone interested in a Linux-based robot solution?
Originally Posted by Peter Johnson View Post
I've been exploring options for a Linux based robot controller for my own projects. Thoughts so far:
- Gumstix Overo Earth COM processor module (http://www.gumstix.com/store/catalog...roducts_id=211)
- Gumstix Chestnut43 I/O board (http://www.gumstix.com/store/catalog...roducts_id=237)
The Overo Earth has a 600 MHz OMAP3503 processor (ARM Cortex-A8 CPU), and 256 MB of RAM, so it's more powerful and has more memory than the cRIO. It will happily boot off a microSD expansion card (you can get 8-16 GB ones nowadays for cheap). Runs Linux like a champ.
The Overo is a good little board and it's frequently used by the aerospace firms (Lock-Mart, NG, etc.) for control operations because it's cheap, fast, and with the PREEMPT_RT patch in place, capable of good determinism using Linux. It also runs quite nicely on a couple of AA batteries. With a set of USB I/O, the Overo board would be an excellent alternative. FWIW, you can also run VxWorks on it if you really wanted to.
Another option would be the Beagleboard:
http://search.digikey.com/scripts/Dk...&k=beagleboard
It's a little cheaper than the Overo and has USB I/O on it as well (same processor as the Overo). BTW, the OMAP 3530 on these boards includes a TI C6X DSP engine. Maybe not as hard core as the cRIO FPGA, but still better than relying on the CPU for everything.
The Phidgets SBC (http://www.phidgets.com/products.php...oduct_id=1070), is an ARM with 8 DI, 8 DO and 8 AIs built onto the board for about $260. And VEX has a new ARM 9 controller in the works with similar I/O capabilities. Once the WPILib is ported to Linux, then any of these inexpensive boards could be used with the same tool chain and O/S release. This would simplify the certification process if FIRST would consider it.
Mike
Running MPLAB and JEDIVCS under Gutsy-based Linux Distributions? techwizrd Programming 13 13-01-2008 19:34
Anyone interested in a webserver? Leon Machado IV Website Design/Showcase 14 25-08-2003 19:45
Anyone interested in winning a Segway? ateene Dean Kamen's Inventions 4 24-10-2002 18:38
Anyone interested in a Mascot competition? DUCKIE Chit-Chat 6 05-04-2002 21:31
