Go to Post Team 233 cannot wait for the Florida Regional, but they have to because they have to build a robot or something first. . . - IbleedPink233 [more]
Unread 27-04-2010, 09:53
Re: Unexpected results from Encoder::GetRate()
Originally Posted by vamfun View Post
I beg to differ again.... what is important is the relative accuracy and that is referenced to the new edge ticks. When a new edge is detected, a mark is made in the sand. You travel one tick to another new edge. You make a second mark in the sand. You know that you have traveled exactly one tick from your first mark.
You don't know that. You know you have traveled at least one tick. You might have traveled almost two ticks. That's what the [1 .. 2) notation Joe used means.
If you now reverse slightly and get a same edge indication... you will always say that you are at the 1st mark when indeed you know that you are not.
What you know is that you are between the first and second marks.
Hence no matter what the relative scaling, when a reverse edge occurs... my algorithm will always be better than yours since its says I'm at the second mark which is indeed where I am.
You were at the second mark for a moment. Until another edge occurs, you don't know precisely where between the first and second marks you are.
I think we all agree that both algorithms will have a max error of 1 count and this will occur at different times.
It is reasonable to consider the true quadrature algorithm to have a maximum error of a half count either side of zero. Again, this is typical of an optimum quantization process.
If you demand exact repeatability with angle, then Joe's is the way to go. However, it introduces large rate spikes when oscillating over an edge.
What rate spikes? I think you missed the part where the FPGA doesn't compute a rate until two events have occurred in the same direction.
The number that a quadrature decoder yields does not represent an edge. It represents a region between edges. Does that help you understand the explanations here?
[BB] An unexpected change in plans yodameister General Forum 22 01-12-2009 21:26
Inconsistent reading from encoder get rate rwood359 National Instruments LabVIEW and Data Acquisition 5 13-01-2009 19:10
Results from Drexel, thanks from 365. archiver 2001 1 24-06-2002 02:44
Results from GLR? archiver 2001 0 24-06-2002 02:44
results from regionals archiver 2000 0 23-06-2002 22:31
