Go to Post Kudos to you IFI, for your continued support of FIRST and its stated ideals - Racer26 [more]
Unread 27-03-2010, 02:04
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Repair of 2007 Victor 884
Ok... I give up. What is the secret of opening up a 2007 Victor 884 that has no screws on the bottom or top?
Seems like Innovation First doesn't want to make it easy to get to the circuitry like we could with the 2004 884.
Unread 27-03-2010, 02:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Repair of 2007 Victor 884
Push and pry. It breaks the case when you do it, so you'd have to reassemble with glue. Also, the transistors used in it are not a real easy to find item if I recall.
Unread 29-03-2010, 11:09
Chris,
A putty knife or some other long object inserted around the base will open the case. It is just friction fit. Be patient and don't try to pry open one side too far before moving on.
Unread 29-03-2010, 19:34
AKA: Chris
FRC #0599 (Robodox)
Al,
Friction is a kind word... more like #%^$*& stuck for good. So I had to push and pry and of course several of the little black pins snapped off like sanddrag said but its open. I think Innovation First was out of their minds to save a little on screws. Now I begin the search for some 3103 Fets.
Unread 30-03-2010, 18:58
DonRotolo's Avatar
Back to humble
FRC #0832
Digi-Key sells them. There is an alternative number IIRC, try this post
Unread 30-03-2010, 20:36
Gdeaver Gdeaver is offline
FRC #1640
I have a 2007 victor 884 and it used Infineon IPP042N03L FETS available from digikey.
Unread 30-03-2010, 23:33
Chris,
Maybe the FETs over temped and melted some of the case together. I have opened several over the years and didn't have that much trouble. Sometimes it is helpful to show a team just how much crud can build up inside on the robot.
Unread 31-03-2010, 02:34
AKA: Chris
FRC #0599 (Robodox)
I finally got around to looking at these and they indeed are Marked 2n03L13 which translates to a Infineon SPI42N03S2L-13 based upon this spec:
http://www.infineon.com/dgdl/SPP_B_4...12b4271adf3b95
So we only have 42 amps instead of the 60+ from the IRL 3103.
This shows up as an obsolete item on DigiKey:
http://search.digikey.com/scripts/Dk...SPI42N03S2L-13
Also noticed the board is marked 883 Rev F.
Anyone come across a ckt for an 883/884 yet or are we stuck with generic ckts?
Unread 31-03-2010, 06:38
They are wired in parallel for 126 amps each leg. Slightly higher series resistance.
Unread 31-03-2010, 07:57
FRC #1640
I don't have time to do it this morning but I believe the IPP042N03L G matches ok with the others. You can check the data sheet for the match ups. I believe I used these and they seem to work fine.
Unread 31-03-2010, 13:10
AKA: Chris
FRC #0599 (Robodox)
Ok..lets compare (Vdss,Rds_on,Id)
IRL3103 30v,12mho,64 amp 2004 Victor
2n03L13 30v,12.9 mho,42 amp 2007 Victor
042N03L 30v,4.2 mho,70 amp Gdeaver replacement
So the 042N03L looks more capable and would make a nice substitute. But this raises a question: What constitutes a First legal 884?
AllElectronics is a few blocks from me and has a stock MTP75N03HDL
http://www.datasheetcatalog.org/data...75N03HDL-D.PDF
MTP75N03HDL 25v,9 mho, 75 amp AllElectronic sub
This might work too, but probably shouldn't be legal for competition right?
Unread 31-03-2010, 14:40
I think per <R60> it wasn't legal as soon as the case was opened.
Unread 31-03-2010, 15:09
AKA: Chris
FRC #0599 (Robodox)
I'm with you there Joe. "shall not be tampered with, modified, or adjusted in any way (tampering includes drilling, cutting, machining, gluing, rewiring, disassembling, etc.) " Seems clear that disassembling for home repair makes your 884 a practice controller even if replacing with OEM parts. So we really might be better off getting a certified repair and saving a few bucks there if the competition supply is getting low.
Unread 27-04-2010, 16:34
AKA: Chris
FRC #0599 (Robodox)
Email response from IFI. So much for a certified repair
Chris,
If you have blown FET’s on your Victors, we generally don’t attempt to repair them. There are parts that have been compromised beyond just the FET’s and the cost becomes more to repair than to replace.
Regards,
Tom Watson
VEX Robotics
(903) 453-0820
Unread 03-06-2010, 00:37
Has anyone actually successfully repaired one? It seems there are large copper busses in the middle of the board, which sink all the heat away when trying to clear the through-holes. After giving this a try, I now know why IFI doesn't bother repairing any.
Victor 884 Issues BHS Bucs Electrical 3 01-02-2008 15:10
Victor 884 Devo1098 Electrical 6 29-06-2007 07:51
Victor 884 problem Gal Longin Control System 11 26-01-2005 00:47
Victor 884 Kevin Ray General Forum 25 28-01-2003 15:02
Victor 884 Gary Bonner Technical Discussion 4 14-01-2002 08:10
