#19
Re: No Robot Code!!!
If you call a old function from an old version of WPILib (assuming you have the right headers), it will compile fine, but linking will throw lots of symbol errors. this can also be an artifact of a c++ feature: every cpp file is compiled by itself, and then linked together at the end, so when you change a file, only the changed file has to be recompiled. sometimes when you update, a file is not recompiled with the new changes, so it can also throw the error the best way to twart this is to recompile the project (solved all of our symbol errors this year): right click the project and click rebuild Quote:
1) Check "No App" switch. 2) Reformat/reimage cRIO. (v20) 3) Run WindRiver updates. (4.3) 4) Run driver station updates. 5) restart driverstation, restart cRIO, restart WindRiver 6) rebuild (right click project, rebuild) 7) Load new code. Hope it works! ![]() |
| No Robot Code | SidneySalvo | NI LabVIEW | 25 | 18-02-2010 17:09 |
| No Robot Code After downloading Code | tutkows1 | FRC Control System | 2 | 08-02-2010 00:51 |
| No Robot Code | eaglesfan10 | C/C++ | 6 | 03-02-2010 22:34 |
| Compressor Code causes No Robot Code Error | sircedric4 | C/C++ | 25 | 03-02-2010 10:13 |
| No Robot Code | mlim | NI LabVIEW | 10 | 21-01-2010 17:33 |
