Go to Post Thank you NASA (except for Dave, his tormenting hints make us even) - Mike Schroeder [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 08-04-2010, 21:46
nitneylion452's Avatar
AKA: Joe Lee
HTML/Website Help
I am just learning how to use HTML to make a website, an this is what I have so far: http://www.team3167.webs.com
I have one problem, every time the home link is clicked, a new red bar with the FIRST logo appears. Does anyone have any ideas on why this is happening? I'll attach the code as soon as I save it to notepad. Thanks in advance for your help!
File Type: txt index.txt (280 Bytes, 27 views)
Unread 08-04-2010, 22:13
dk5sm5luigi's Avatar
dk5sm5luigi dk5sm5luigi is offline
AKA: Nick Galotti
FRC #1735 (Green Reapers)
dk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud of
Send a message via AIM to dk5sm5luigi
Re: HTML/Website Help
Welcome to the world of HTML. I can't replicate the problem, but it is probably because you are using frames. Frames are an older technology in the web world and really shouldn't be used anymore. The new HTML5 standard doesn't even support them.
If you use DIVs and style them with stylesheets you should be able to get the same effect.
Let us know if you have any questions.
Team 1735 Green Reapers: 2005-Present
Team 190 Gompei: 2001-2005
Team 155 Technonuts: 1997-2001
http://www.first-a-holics.com/
http://www.findrobotparts.com/
Unread 08-04-2010, 22:53
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
I can't reproduce it either.
What browser (and version) are you using?
Unread 08-04-2010, 23:14
PriyankP's Avatar
PriyankP PriyankP is offline
FRC #0188 (Woburn Robotics)
PriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud of
I couldn't reproduce the error with Firefox but this code might explain the red.
<frame noresize="noresize" style="background-color:red"
src="http://www.iolani.honolulu.hi.us/robotics/newweb/allimg/home/first_logo_1.jpg" width="10%" height="100%"">
<frame noresize="noresize" src="home.htm">
Try taking the "background-color:red" out and see if that solves the problem.
Champs Schedule Highlighter App [CD Thread]
#### XYZ Regional Finalists
Unread 11-04-2010, 13:27
AKA: Joe Lee
I had since originally posting edited the code, which fixed the error to the new bar would come up only after going to a different page, then clicking home. I just changed the code back to exactly how it was before, so you may be able to reproduce the problem now. I've used IE 6, IE 7, IE 8, Firefox 3.5.9, and Firefox 3.6.
Unread 11-04-2010, 14:03
synth3tk's Avatar
AKA: David Thomas
You might want to play around with this:
http://www.w3schools.com/tags/att_a_target.asp
Also, this is how I see the site from Google Chrome (it's fine for other browsers):
http://team964.com/misc/imgs/team3167.png
Unread 11-04-2010, 16:09
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Those nav links open in the same frame, so the "Home" link is opening index.htm within that frame. But index.htm contains multiple frames, so you're opening a page with frames inside a frame.
I'd either look at the target attribute as synth3tk suggested, or just change the home link to "home.htm" instead of "index.htm".
I'd also avoid using anything but another HTML page for the frame content (namely, in the top frame).
Also, remember that using frames means users can't bookmark individual frames on the site. At the same time, you can't prevent people from going directly to one of the pages (e.g. http://www.team3167.webs.com/About_3167.htm) in which case they won't see the top frame at all.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 11-04-2010, 21:28
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Originally Posted by nitneylion452 View Post
Is there a way to make code only run once? I know some java and I know that you can use if-else statements to skip code if something is or is not true. Is there something in HTML that allows me to say something like if the frame is being displayed, do not redisplay it?
The first rule of post-1990s web development is don't use frames. The second rule is don't use frames.*
Sorry if it sounds harsh, but using frames to build modern websites is like designing a car to run off of a steam engine. Yes, it'll work, but there's a very good reason why the production of steam-powered cars was abandoned (it's very inefficient). Frames will technically work to make websites, but they have so many problems and require so many awful "hacks" just to make them work somewhat decently, that the practice of using them to make websites has been officially abandoned.
* Small amounts of iframes (they're different from frames) are acceptable when used sparingly. I've used small iframes to do Gmail-style AJAX file upload before.
Art Dutra IV
世上无难事,只怕有心人.
Unread 11-04-2010, 21:35
AKA: Joe Lee
I used frames for one reason and one reason only: That's what was in the W3C schools tutorial. I got a similar effect on the site now by adding the images to the top before the nav bar and using aligning and page percentages. I think it looks better now than it did before.
Thanks everyone for your suggestions!
Unread 11-04-2010, 22:47
synth3tk's Avatar
AKA: David Thomas
If you really want to get advanced, you could do this with PHP (assuming you're using PHP instead of straight HTML).
Create a file named "header.php", then use a php include to pull that "header.php" in every page (you've got to put the code on each page).
The benefit is obvious: make changes to header.php, and it changes on every page that calls it, across the site. Another benefit is that you won't run into pesky frame issues.
But I don't know what you're using to edit/publish this site, so the above may not work for you.
Unread 12-04-2010, 10:35
7
FRC #1712 (Dawgma)
Yeah, frames aren't a great idea for layout, but they're worth learning since they're still used in many web apps (often invisibly). The key with what you were trying to do is to be precise with your links.
Unread 12-04-2010, 18:36
AKA: Joe Lee
I'm using webs.com to host and edit the site. The only files they allow when creating a page are .htm and .html files.
Unread 27-04-2010, 17:51
AKA: Joe Lee
I'm back with a new problem and figured that it would be best to just continue this thread, rather than start a new one.
I made the website and have the basic layout set up as far as a header, body, and footer. The website looks exactly how I want it to look in Mozilla Firefox, but in Internet Explorer 6,7, and 8, it looks terrible. If you use IE, take a look at what I mean http://www.team3167.webs.com If you could, can anyone look at the HTML and give a possible explanation as to why it appear as it does? (For people using browsers other than IE or Mozilla Firefox, it would be greatly appreciated if you could tell me what the website appears like by possibly including a picture.)
Thank you in advance for your help!
Name:	IE Website appearance.jpg
ID:	9065  Click image for larger version
Name:	IE Website bottom.jpg
ID:	9066  Click image for larger version
Name:	Firefox Webside good.jpg
ID:	9067  Click image for larger version
Name:	Firefox Website bottom.jpg
Unread 27-04-2010, 18:50
1986titans's Avatar
1986titans 1986titans is offline
1986: It's a team #, not a year.
AKA: Paul Shackelford
FRC #1986 (Team Titanium)
1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future
It looks like that in Firefox too, at least on Ubuntu.
This seems to be the culprit:
<img src="http://www.iolani.honolulu.hi.us/robotics/newweb/allimg/home/first_logo_1.jpg" height="90%" width="90%" align="center">
That would mean that it's taking up 90% of the page vertically and horizontally. Use pixel values ("100px" etc.) instead as it wouldn't change with window size/screen resolution.
Paul Shackelford - http://www.archkc.com/
Kansas State University - Electrical Engineering '15
Team Titanium - Lee's Summit West HS - FRC 1986 - Student [2009-2011] - Captain [2011] - College Mentor [2012]
Last edited by 1986titans : 27-04-2010 at 19:12. Reason: Fixing code, I was in a hurry the first time through.
Unread 27-04-2010, 21:15
gloomy_lion's Avatar
gloomy_lion gloomy_lion is offline
FRC #2199 (Robo-Lions)
Team Role: Webmaster
gloomy_lion is an unknown quantity at this point
I recommend getting your HTML valid before going on. Firefox can be pretty forgiving when it comes to misplacing tags and not closing elements, but IE requires you to be really careful with your coding.
http://validator.w3.org/
Personally, I think the problem is being caused by the following code:
</head>
<div id="container">
<a href="http://www.usfirst.org" target="_blank"> <img src="http://www.iolani.honolulu.hi.us/robotics/newweb/allimg/home/first_logo_1.jpg" border="0" width="10%" height="10%"></a>
<a href="http://www.comcast.com" target="_blank"> <img src="http://gothampr.files.wordpress.com/2009/12/comcast_logo.jpg" border="0" width="15%" height="10%" align="right" image-align="top"></a>
<a href="http://www.etcusa.com" target="_blank" > <img src="http://etcusa.com/img/logo.gif" border="0" width="20%" height="10%" align="right"></a>
<style type="text/css">
#navbar ul {
    margin: 0;
    padding: 5px;
    list-style-type: none;
    text-align: center;
    background-color: #000;
#navbar ul li {
    display: inline;
#navbar ul li a {
    text-decoration: none;
    padding: .2em 1em;
    color: #fff;
#navbar ul li a:hover {
    color: #000;
    background-color: #fff;
</style>
</head>
<div id="body">
<body>
You enclose your links and your styles between two </head> tags. Get rid of the first </head> tag, and hopefully you'll be on the right track. You also include a <div> element outside of the <body> tags, which is probably also why IE is giving you grief. Just be careful to keep your code valid and your troubles with cross-browser compatibility should be somewhat lessened .
Website Help Elvenage Website Design/Showcase 0 06-02-2009 16:45
HTML Help Thread Compnerd Website Design/Showcase 1 13-02-2007 18:33
Website Help Dan50 IT / Communications 3 25-01-2006 07:00
Help with HTML LBK Rules CD Forum Support 3 03-02-2003 12:38
