Go to Post My favorite question of all time asked by "outsiders": How much does/did that thing cost? How can you put a price on the hard-work and dedication it took to build these machines? - KyleGilbert45 [more]
Unread 29-04-2010, 11:35
Cl4p-tp's Avatar
Cl4p-tp Cl4p-tp is offline
Scott Clark
AKA: Scott Clark
FRC #2062 (C.O.R.E 2062)
Cl4p-tp has a little shameless behaviour in the past
Attempting the impossible
Thats right, a chain-less drive train for an off season project. Any ideas?
Unread 29-04-2010, 11:37
Joining the 900 Meme Team
FRC #0079
Re: Attempting the impossible
What do you mean impossible?
Why? Have you considered using timing belt? (See 125 in 2008 if I recall)
Unread 29-04-2010, 11:41
hayonet's Avatar
hayonet hayonet is offline
Mechanical/CEO
AKA: Hayon
FRC #1676 (Pascack Pi-Oneers)
hayonet is on a distinguished road
I believe you may be referring to a belt-driven drive train. Many teams have done this in the past. As long as the belts are properly tensioned, they can work as well as chain, with much less weight.
Here is a white paper on the topic.
Here is one of many threads discussing this.
Good Luck,
Ethan
Unread 29-04-2010, 11:50
Bmcdonnell Bmcdonnell is offline
FRC #2062 (C.O.R.E. 2062)
Bmcdonnell is an unknown quantity at this point
Our team is attempting to achieve this over the summer, well at least we are thinking about trying to try it...
I'm not really sure how we would do this though because I'm not on mechincal, but I'm hoping we succeed. Our chains broke in our final matches in Atlanta.
Unread 29-04-2010, 11:54
Best Available Data
FRC #1778 (Chill Out!)
Impossible? I mean, I know AndyMark sells lots of stuff, but I didn't know they sold the Impossible as well!
In all seriousness, I think the Aztecs (157) did a timing belt drive in 2005. They may have continued doing them, but I haven't been to a regional with them since. Cyber Blue (234) did a great bit of research on belts vs. chains that you can find on CD-Media.
Hope that helps!
Unread 29-04-2010, 11:55
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Team 51 used a chainless drive this year. It was 4WD and each wheel was gear driven by its own motor. The motor/gear/wheel assembly was made as a module and could bolt on to any corner of the robot.
Unread 29-04-2010, 12:03
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Better not tell Raider Robotix (team 25) its impossible; they've been doing it since 2003.
see also: 703, 1369, 103
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 29-04-2010, 12:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
May I ask why?
Unread 29-04-2010, 12:06
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
well i always did think that mechanum wheels were somewhat witch-craft....most of them are direct driven off a gearbox..no chains
WPI Robotics Engineering & Mechanical Engineering Class of 15
iRobot Mechanical Engineering Intern
Unread 29-04-2010, 12:09
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Ours also had no chain, but that's easy with belts.
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 29-04-2010, 12:18
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
how about using shafts and bevel gears
Bruce
Unread 29-04-2010, 12:25
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
1517 was a belt drive this year, mecunams normally don't use chain as BEEKMAN said, I think 126 had a belt drive in 2008, and pretty much it is not that hard to have a chainless drive.
What type of drive are you guys considering? It does sound like a neat project to use something you haven't done before, I guess that is why they call it off-season, belt, direct drive, sprockets, other?
1058 PVC Pirates 2016 - xxxx
Unread 29-04-2010, 12:51
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
We used timing belt this year to great success. I still have to question why you are so adverse to chain. Properly set up, you should never break a chain. Maybe instead of finding an entire new way of transmitting power you should look at improving your current chain setup and figure out why it didnt work. If something was wrong in the chain setup, you will surely have the same issues with belt or direct drive as those really require even more precision and thought.
Mentor 2415
Unread 29-04-2010, 13:05
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Can you or someone else on your team elaborate on this a little bit more? I'm curious to how you actually broke chain, we've done some interesting (dumb) stuff with both #25 and #35 chain and have never actually broken the chain.
Usually, when teams have problems with chains it's because of implementation and not the actual chain itself. Proper alignment and tension have solved any issue that I've ever had with chains.
But, on the original topic, having a drive train that doesn't use chains is uncommon but not impossible. Personally, I'm biased towards the 25 method of building drive trains around gears, and I think I may experiment with this a bit in the off season. On thing you may want to consider about moving away from chains is that you'll need increased precision in your implementation to use just about anything else. I've found that #35 chain is pretty forgiving to loose tolerances, but gears and belts aren't...
-Dustin Benedict
Unread 29-04-2010, 13:07
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If your "chains broke" in several matches, going chainless (unless you only have four wheels, each direct driven) via gears/belts will only make the problem worse. Gear and belts need higher tolerances than [35-pitch] roller chain does.
If your chains broke, it's probably because they were improperly tensioned or misaligned. Look at solving these problems before you write off chain and attempt something else. If you don't solve the root causes behind your chain failures, the same issues will affect whatever other drive train design you implement.
Art Dutra IV
世上无难事,只怕有心人.
Attempting the Bonus Round bensherman Rules/Strategy 18 13-01-2010 15:49
pic: Duece Attempting to Remove A Spoiler IraJason Extra Discussion 11 04-04-2007 23:36
Attempting to Cut BaneBot 56mm Shaft edthegeek Motors 6 15-01-2007 08:51
To Dream the Impossible Dream (Full Version) Ken Leung General Forum 16 01-01-2007 12:41
568 making the impossible possible...kinda Draqo Control System 6 24-03-2005 10:26
