Go to Post Keep in mind that the lady Amanda has just taken a new job, moved herself to the NorthEast, and has to put up with people like Grady, Needel, the Kelsos, and Boucher. Let's give her some patience and sympathy. - Andy Baker [more]
Unread 29-04-2010, 17:16
The Analog's Avatar
The Analog The Analog is offline
AKA: Aaron Swope
FRC #0079 (Krunch)
The Analog is an unknown quantity at this point
Send a message via AIM to The Analog
Swerve Drive Idea
I'm designing a robot, and have decided to implement a swerve drive. I'm loosely basing the swerve modules on 221's Wild Swerve. These modules have a CIM motor, and gear box on the pod. I would like to be able to turn these modules without any restriction, but those darn wires will get in the way. So, I was thinking of a way to solve this issue, and this is what I came up with.
place 2 stationary metal rings around the module, so it can turn freely, then use pvc, or something to that effect to rout the wires from the CIM to the ring, then attach the wire to a metal wheel and axil assembly (like one on a model train) and use the ring like a track. The ring can then be attached to a Jag/Victor with stationary wires.
This entire assembly, can then be encased in lexan/plastic/something to keep hands away from current.
I would love to here what you think about this idea, any improvements, and/or any constructive criticism
Swerve Drive DuskProgrammer Programming 7 16-01-2010 09:29
Swerve Drive Team1710 Technical Discussion 11 07-03-2009 09:58
Swerve drive 4, 2+2? kirtar Technical Discussion 18 02-04-2008 06:58
Swerve Drive on a Jeep Karthik Math and Science 3 01-02-2005 17:50
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
