Re: Swerve Drive Idea
You're looking for something called a "slip ring."
What you've described is a rudimentary sort, but you can purchase something to do the job as well. |
Bearing in mind they were illegal this year in FRC and may continue to be in the future.
I seem to have missed this. Under what rules were they illegal?
This is not a FRC bot, so I'm not too worried about the rules, but I would like to find a solution that COULD be implemented by teams
They were legal in 08.
EDIT: http://www.chiefdelphi.com/forums/sh...07&postcount=3 Al made the comment from a Q&A answer. It says R47 but I don't have a rulebook in front of me. Yup, and 190 used them well. Last edited by Andrew Schreiber : 29-04-2010 at 17:39. |
#7
It may be easier to make a hollow main pivot axle so that you can pass the wires out the top of the module.
A few teams did this sort of modification to Wild Swerve units this season. frc20 is one that comes to mind. |
#8
We did this for our Swerve for Triple Play, and it didn't end well. Eventually the wires will twist and fray, even with programming constraints to avoid as much steering and overturning as possible.
#9
I recall frc469 in the past few seasons auto unwinding their swerve modules when they were sitting still to avoid wire issues. You can always go coaxial. ![]() |
#10
Team 190 used homemade high power slip rings for their arm in 2008. I believe they worked quite well. If you want more information I can ask someone who was on the team in 2008 to PM you.
#11
Team 20 had code to center the wheels whenever they are sitting still. They could rotate 1440 degrees total (2 spins either way, limited by the 10 turn pots). We had no noticeable damage to the wires after 3 competitions. We were planning on using magnetic encoders to detect position plus slip rings to have unlimited spins, but that didn't work out.
#12
I don't mean visually, I mean unattractive in a mechanical sense. I don't like coaxial drive shafts, and extra chain drives that can fail.
#14
the rule jspatz1 was mentioning that was clarified to us was R50
"<R50> Custom circuits shall NOT directly alter the power pathways between the battery, Power Distribution Board, speed controllers, relays, motors, or other elements of the robot control system (including the power pathways to other sensors or circuits). Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the ROBOT’S electrical system is acceptable, because the effect on the ROBOT outputs should be inconsequential." they just clarified that absolutely nothing besides the copper wires can be used. some members were confused with the clarification and thought of similar ideas, that were still illegal because they would violate the rule. |
#15
please do, Thanks
| Swerve Drive | DuskProgrammer | Programming | 7 | 16-01-2010 09:29 |
| Swerve Drive | Team1710 | Technical Discussion | 11 | 07-03-2009 09:58 |
| Swerve drive 4, 2+2? | kirtar | Technical Discussion | 18 | 02-04-2008 06:58 |
| Swerve Drive on a Jeep | Karthik | Math and Science | 3 | 01-02-2005 17:50 |
| Swerve Drive | Jeff Waegelin | Technical Discussion | 14 | 17-09-2001 08:06 |
