Go to Post I don't miss the manufactured magic of Disney because Championships creates magic in itself; wherever the event may be held. - Erin Rapacki [more]
Unread 29-04-2010, 17:16
The Analog's Avatar
The Analog The Analog is offline
AKA: Aaron Swope
FRC #0079 (Krunch)
The Analog is an unknown quantity at this point
Send a message via AIM to The Analog
Swerve Drive Idea
I'm designing a robot, and have decided to implement a swerve drive. I'm loosely basing the swerve modules on 221's Wild Swerve. These modules have a CIM motor, and gear box on the pod. I would like to be able to turn these modules without any restriction, but those darn wires will get in the way. So, I was thinking of a way to solve this issue, and this is what I came up with.
place 2 stationary metal rings around the module, so it can turn freely, then use pvc, or something to that effect to rout the wires from the CIM to the ring, then attach the wire to a metal wheel and axil assembly (like one on a model train) and use the ring like a track. The ring can then be attached to a Jag/Victor with stationary wires.
This entire assembly, can then be encased in lexan/plastic/something to keep hands away from current.
I would love to here what you think about this idea, any improvements, and/or any constructive criticism
Unread 29-04-2010, 17:22
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Swerve Drive Idea
You're looking for something called a "slip ring."
What you've described is a rudimentary sort, but you can purchase something to do the job as well.
--Madison--
...down at the Ozdust!
Unread 29-04-2010, 17:27
Joining the 900 Meme Team
FRC #0079
Bearing in mind they were illegal this year in FRC and may continue to be in the future.
Unread 29-04-2010, 17:29
The Analog's Avatar
AKA: Aaron Swope
FRC #0079 (Krunch)
something like that, but the ones I've seen, wont go around the swerve module, see,
Unread 29-04-2010, 17:30
CraigHickman
Posts: n/a
I seem to have missed this. Under what rules were they illegal?
Unread 29-04-2010, 17:31
The Analog's Avatar
AKA: Aaron Swope
FRC #0079 (Krunch)
This is not a FRC bot, so I'm not too worried about the rules, but I would like to find a solution that COULD be implemented by teams
Unread 29-04-2010, 17:32
AdamHeard's Avatar
Lead Mentor
They were legal in 08.
Unread 29-04-2010, 17:37
FRC #0079
I'll double check this but I do recall reading something about it, I could just be remembering something else.
EDIT: http://www.chiefdelphi.com/forums/sh...07&postcount=3 Al made the comment from a Q&A answer. It says R47 but I don't have a rulebook in front of me.
Yup, and 190 used them well.
Unread 29-04-2010, 18:05
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
It may be easier to make a hollow main pivot axle so that you can pass the wires out the top of the module.
A few teams did this sort of modification to Wild Swerve units this season.
frc20 is one that comes to mind.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 29-04-2010, 18:27
CraigHickman
Posts: n/a
We did this for our Swerve for Triple Play, and it didn't end well. Eventually the wires will twist and fray, even with programming constraints to avoid as much steering and overturning as possible.
Unread 29-04-2010, 18:31
AKA: Anthony Lapp
Agreed, this can be an issue.
I recall frc469 in the past few seasons auto unwinding their swerve modules when they were sitting still to avoid wire issues.
You can always go coaxial.
Anthony Lapp
RobotOpen
Unread 29-04-2010, 18:37
The Analog's Avatar
AKA: Aaron Swope
FRC #0079 (Krunch)
This is what I'm trying to avoid, I want to be able to make an infinite number of turns, and not have to worry about the wires. I think that by having stationary rings, and in turn, stationary wires, this will prove to be far superior.
I have looked into 118 swerve drive units, but I like larger wheels, and the dual chain drive just seems unattractive to me.
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Team 190 used homemade high power slip rings for their arm in 2008. I believe they worked quite well. If you want more information I can ask someone who was on the team in 2008 to PM you.
Unread 29-04-2010, 18:43
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Team 20 had code to center the wheels whenever they are sitting still. They could rotate 1440 degrees total (2 spins either way, limited by the 10 turn pots). We had no noticeable damage to the wires after 3 competitions. We were planning on using magnetic encoders to detect position plus slip rings to have unlimited spins, but that didn't work out.
Unread 29-04-2010, 19:29
CraigHickman
Posts: n/a
This might sound harsh, but if "attractiveness" is a heavy design influence for you, you might want to examine your design expectations...
Swerve Drive DuskProgrammer Programming 7 16-01-2010 09:29
Swerve Drive Team1710 Technical Discussion 11 07-03-2009 09:58
Swerve drive 4, 2+2? kirtar Technical Discussion 18 02-04-2008 06:58
Swerve Drive on a Jeep Karthik Math and Science 3 01-02-2005 17:50
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
